horn will not stop blowing
Old Jan 15, 2012 | 03:58 PM
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
2005 S320 horn will not stop blowing, took off the relay just to stop it from honking, any idea or experience to share?
Old Jan 15, 2012 | 11:43 PM
cmpcpro's Avatar
2004 CLK 500
You require Jackie Gleason to kick your front tire. Problem solved.
Old Jan 15, 2012 | 11:50 PM
corny reply, grow up.
Old Jan 16, 2012 | 01:36 AM
cmpcpro's Avatar
2004 CLK 500
Well I'm sorry if I've offended you.. You have to admit your horn not turning off is pretty bad.. Reminded me of the old Smokey and the Bandit..
Old Jan 16, 2012 | 02:52 AM
I was not offended at all it's just that technical issues should be taken seriously or at least with some ethical thoughts, it is posted to aid those who may need answer as well as for those who are knowledgeable to facilitate.
Old Jan 16, 2012 | 03:35 AM
desired_speeds's Avatar
2007 SL55 AMG
did it just happen out of the blue or did you hit the horn and it stayed on?
I remember I was in New York a few years back inside a bakery and looked outside to see why someone was laying on their horn. Saw a guy banging on his steering wheel trying to unstick the horn. haha
Old Jan 16, 2012 | 04:18 AM
hit the horn and it stayed on, the steering wheel center pad is not grounded/shorted after checking
Old Aug 31, 2012 | 05:24 PM
tigere's Avatar
ML320 PETROL 1999
hello mate,how did you eventually fix your non stop blowing horn coz mine has got the same problem and i don't know what to do now?
Old Apr 11, 2013 | 07:38 PM
shneo70's Avatar
W210 E230, W220 S280
Hi, I am Neo from Malaysia. I have a similar problem with my year 2004 W220 S280 and hope can get some help here.
When I hit the horn while driving the horn will just stay on. I have to switch off the engine to stop the horn. Everything is fine after turning off and on the engine until I hit the horn again.
This does not happen if I just put the key in the ignition switch, without turning on the engine.
Any idea what could cause this? Some said it could be due to a faulty SAM...
Thanks.
Neo
Malaysia
Old Dec 28, 2014 | 01:12 AM
dungha's Avatar
22 GLE 450
I have the same problem with my 08 ml350 can anyone help !
Old Jan 2, 2015 | 02:01 AM
cybertronicify's Avatar
2003 S430, 2014 E350
Your horn is controlled with a relay and if you have a sticky relay contact then your horn will be stuck on. Check if water got into the fuse box, it may carry enough current to keep the relay latched.
Old Jan 2, 2015 | 09:57 AM
dungha's Avatar
22 GLE 450
[QUOTE=cybertronicify;6280634]Your horn is controlled with a relay and if you have a sticky relay contact then your horn will be stuck on. Check if water got into the fuse box, it may carry enough current to keep the relay latched.
I already change the new relay but not fix the problem. I don't know what next to do. Thanks
Old Jan 6, 2015 | 01:26 PM
dungha's Avatar
22 GLE 450
Thanks.
Neo
Malaysia
Please let me know how you fix your horn problem. I have same problem you have. Thanks
Old Jan 6, 2015 | 04:33 PM
vmystikilv's Avatar
Range Rover
Change relay, if it still happens then its a bad Sam that controls horn through the relay
Old Jan 6, 2015 | 05:53 PM
dungha's Avatar
22 GLE 450
Can you let me know where is the sam locate it. Thanks
Old Jan 6, 2015 | 06:26 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
How often does it happen? I only had it happen to me once, and disconnecting and reconnecting the battery solved it. Haven't had that issue for 9 months since it happened so I'm guessing my case was a fluke.
