Mystery Hydraulic Fluid Leak on 2005 S600 - Help Please
I have 2005 S600 that has 66k miles on it.
I have recently upgraded from a '97 SL600 and am loving the S600s ride and comfortable cruising.
I bought it in October with 59K miles.
This is rather long winded and my terminology may not be the best, but I ask that you please bear with me as this is very frustrating to try to fix.
I got in the S600 on Thursday morning and all seemed fine until I made it a couple miles down the road.
Then all of the sudden, the ABC Drive Carefully warning lit up on the dash.
I got out and looked under the car and saw a rather large puddle under the front end of the car (it was 3x3 feet or so.) It started in front of the wheels and ended at the oil pan.
There was some fluid left in the reservoir so I limped it home and put it on the lift.
The larger hydraulic fluid tank was now empty but the smaller one was still full. (Does the smaller tank hold the fluid for the power steering pump?)
After sitting for several hours, I was unable to find the source of the leak. It seemed to have stopped.
I added 1/2 of a quart to the larger tank and it was now roughly half full.
Then I removed the plastic skid pans and wiped off as much of the excess oil that was all over the under carriage, in hopes of finding a trail of oil or something.
Still no leak was to be found.
I got in the car and started it up. All was ok for a minute and then the ABC Drive Carefully lit up again and a small drip started. It is coming from the front end, drivers side of the engine bay, underneath the hydraulic fluid tank area. But, things are so tight in there, that I cannot be sure.
I can't seem to find a diagram of the hydraulic lines to source the leak.
Has anyone else had a leak in this area or happen to have photos or suggestions as to where to look?
I tried the local Mercedes dealer. (Where the previous owner had it serviced.) They were too interested in helping or even in fixing it!
So, I am trying to fix it myself, if it is possible lol.
Thank you for any help or guidance that you would be willing to share.
All the best,
Vinnie
Johan
Tusabes: could you provide more information on the recall? I have been looking online and have not come across a recall for this model year.
I will keeping digging for more information and hopefully find the leak.
All the best,
Vinnie
All the best,
Vinnie
I have some good news to report, the S600 is at the shop and being repaired.
It turned out to be the hydraulic lines had started leaking - even though they were replaced less than 7k miles ago!
They will be saving the old lines and have them for me when I pick it up.
Thank you all for your help and I will report more after the car is all done.
Best,
Vinnie
Best,
Vinnie
