AKEBONO pads
Old Mar 10, 2012 | 08:10 PM
Tuscan1311's Avatar
S500 4 matic
AKEBONO pads
Anyone know where i can find AKEBONO front and rear pads for my 2003 s 500 4 matic??? i only find front pads not rear.
Old Mar 10, 2012 | 09:15 PM
trombone's Avatar
2002 S430
Call ROCKAUTO on the phone; they can tell why is it not available if so. Number is on their website rockauto.com.
Old Mar 11, 2012 | 04:27 PM
Vabene7's Avatar
Garage Temporarily Empty
I would also look on the AKEBONO website.
I have the Euro pads and love them, dustless and high performance.
http://www.akebonobrakes.com/
Old Mar 11, 2012 | 05:20 PM
Quadcammer's Avatar
96 and 08 911 turbos
not made for the 4matic rear.
i went with akebonos up front and ebc redstuff in the back.
Old Mar 18, 2012 | 09:34 PM
Tuscan1311's Avatar
S500 4 matic
Hey do anyone know the parts number for the redstuff rear pads for the 2003 4 matic????
Old Mar 18, 2012 | 09:51 PM
Quadcammer's Avatar
DP31491C
cheapest I've seen $108 shipped
http://racehighperformance.com/brake...-p26690-p.html
Old Mar 18, 2012 | 10:07 PM
Tuscan1311's Avatar
S500 4 matic
Thanks for the link. I need to know Does these brakes hook up to brake sensor wire????
Old Mar 18, 2012 | 10:16 PM
cmpcpro's Avatar
2004 CLK 500
The Akebono's do but there is a front and a back the backs have the holes too far out so even though they look identical you need to put the ones with the holes closest to the backplate up front.. this is especially manditory for the fronts.. backs only have one sensor.
Old Mar 18, 2012 | 10:52 PM
Tuscan1311's Avatar
S500 4 matic
Ok iI will have my mechanic put on akebono. so for theRedstuff has it no sensor on it?
Old Mar 19, 2012 | 09:41 AM
Quadcammer's Avatar
I'm not sure I understand the question.
You take the sensor, and slip it into the middle of the pad. There is a hole for it.
Old Mar 19, 2012 | 11:30 PM
classyS's Avatar
2001 S430
sorry off topic, real quick - what rotors everyone using with their akebonos?
zimmerman or balo? or?
thx
Old Mar 20, 2012 | 08:44 AM
Quadcammer's Avatar
OEM, they are not expensive
Old Mar 21, 2012 | 10:16 PM
Vabene7's Avatar
+1
Old Mar 22, 2012 | 09:19 AM
Sgt. Schultz's Avatar
opposite-lock...
where you guys source these OEM rotors? I'm nearing due on fronts
I'll be running a more aggressive pad when time comes, hoping Ferodo DS2500 is avail for these - have to check.
Verymuch looking fwd to 'that' - these OEMs (can) fade scarily on 3rd hard hit
Old Mar 22, 2012 | 11:53 AM
Quadcammer's Avatar
oediscountparts.com
$300 each with free shipping.
Even with aggressive pads, the s600 brakes are just not up to the job. its a 4800lb car, the brakes are just not enough
Old Mar 22, 2012 | 02:53 PM
opposite-lock...
ouch
pricey bits, those are!
4600lb
so... you've driven a pad'd 600 then?
the brakes are plennnty strong and large - the pad fade resistence is lacking tho
Old Mar 22, 2012 | 03:15 PM
Quadcammer's Avatar
fade after 3 hard stops is not plenty large or strong. Then again its not a sports car.
I've driven a few of the V12 cars, the only ones that stopped well were the 65s. The initial bite on the 600 was a bit weak, but the brakes were overall ok. As you noted though, the fade is apparent. I also don't like the mushy brake pedal all Mercedes seem to have either.
Old Mar 22, 2012 | 03:31 PM
opposite-lock...
still thinking pads is going to make an acceptable difference
hmmm - my pedal is fantastic, not at all mushy whatsoever, and my intial bite is great!
you must have driven so-so examples
they are definitely plenty strong - they just fade, which is typically pads (14" rotor is plenty big enough of a sink, and fixed 4piston Brembo cals don't exactly suck)
Old Mar 22, 2012 | 04:46 PM
Quadcammer's Avatar
Pads will likely help, but with an aggressive pad, you are going to give up cold braking performance and will noticeably reduce pad life. Saying nothing of dust and potential noise also.
You mean to tell me that you would get out of your 930, and then get into your s600 and say that the s600 has a firm pedal?
Fade is the result of a number of things, not just pad compound. 14 rotors, while big, are not outrageous on a heavy car. Brake fluid with a higher boiling point is also crucial.
I wasn't impressed with the S600 brakes, but I'm not all that impressed with the big reds on my 993TT either.
