2003 s430 closing assist pump
Old Sep 13, 2012 | 12:39 AM
w220lover's Avatar
my drivers door doest suck in, but all others do, is that normal and if not how to fix it, thanx.
Old Sep 13, 2012 | 03:42 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
When the door is shut to where it should suck in do you hear an air sound coming from the door?
Old Sep 13, 2012 | 08:03 AM
w220lover's Avatar
re:
no i do not hear it on the drivers door, but i do on all other doors and it does suck it in.
Old Sep 13, 2012 | 03:11 PM
DNA47's Avatar
Facelift GLC43
The same thing happened to my passenger door a couple of weeks ago...if you don't hear what OCKlasse described, then i think it's not a leak but the closing assist pump that is gone.
Old Sep 15, 2012 | 02:38 PM
la22bay's Avatar
2014 S550 4matic 2003 SL500 2009 CLS550 2008 CLK350 2002 L320 2006 E350
No that's not it the module behind the switch to seats is going bad had problem 2 weeks ago. must replace the seat switch/module on that door cheapest i found $384 plus shipping mercedesbenzparts.com
Old Sep 16, 2012 | 03:01 AM
DNA47's Avatar
Facelift GLC43
what you could do is disconnect the yellow 20 amp fuse located under the rear passenger seat (same as disconnecting the battery, but you won't have to re-sync your windows and sunroof) and look if the closing assist then works. if it does, then you'll know you have a leak (but don't repeat this process too often or you'll end up burning your pump).
If this doesn't work then you'll know that your pump is out (but i doubt it cause i think there's is only one pump for all the doors/trunk and the other doors are working, right?) or what la22bay said needs to be replaced.
But to be honest with you, we've been 'completely' closing doors all our lives, sure it's a nice feature, but i doubt it's worth paying a large sum of money to repair it..just my 2cents
I'm no expert so i hope i helped
Old Sep 16, 2012 | 03:16 AM
cmpcpro's Avatar
2004 CLK 500
If it was mine Id fix it. But I get funny about that stuff. I want it working if its supposed to be..
Old Sep 16, 2012 | 01:28 PM
DNA47's Avatar
Facelift GLC43
btw to be clear i think it's fuse #62 but i could be wrong
@cmpcpro yeah i get your point, but stills..
Old Sep 24, 2012 | 01:30 PM
aasim305's Avatar
2003 s430
My driver side door i hear air leaking and its not closing. what can it be?
