2003 S430 Shaking/Minor Rough Idle
I have a 2003 s430 with 87k miles,it has been completely serviced according to maintenance records recieved prior to purchase.When I start the car in the morning,its starts with no issues,but while warming it up,the car begins to shake,only in park might I add,not in drive.Its minor,but noticable.
I want to remind you,it dosent do this while in drive,only in park.The rpm's remain steady,and when i take off,the issue is gone.Its not a huge complaint due to the fact it performs as if it was new,but its bothering me thinking that it could be something that should be replaced.
I have considered pulling the o2 sensor,but I havent worked on a car of this type before,mostly older american cars.Any thoughts on where to start?Any help would be appreciated!
-Just wanted to add,the shaking is sort of on and off,some days it does,some days it dosent,after driving the car one day,it was at normal temperature,I stopped at the store,left my wife in it while it was running,and she said it was shaking.
if you don't get misfire codes, have had your motor mounts checked, and its as minor as you say it is (and is on my car), its nothing to worry about, especially since it goes away when it warms up.
I have a 2000 s500 I have the same proble like most of you guys..when driving and speed reaches to 45 it vibrates a bit so I tought it was something with the tires or rims or control arms and as such, after long investigation it figures that the vibration that comes from under your seat can be 2 major things either your differential or the transmission mount ..tomorrow im going to do a replacement of both and check other things too, if the vibration is not gone im going to tear my car apart until I find out what it is..i will post an update
Happy for now. It was an easy fix.
Other symptoms were: notable decrease in fuel efficiency and very low power when driving (I could not drive fast).
I changed both ignition coil with new ones from Bosch, which solved my issue.
