any new info on lowering...
Old Aug 11, 2003 | 04:37 PM
Kerr's Avatar
G500,toyota supra, 67corvette,05 pathfinder
Just wondering if anyone has come up with a new way or kit, to drop a S class with out buying that $2,XXX kit. Also any one had any more luck on getthing the factory computer switched to all countrys setting or what ever it was that lowered it .5
thanks
Shawn
Old Aug 12, 2003 | 01:45 AM
randall-sd's Avatar
This one did not use the $2,xxx lowering kit you mentioned.
Old Aug 12, 2003 | 02:03 AM
shaggy982's Avatar
2000 Mercedes S500
if you get the performance products catalog, you'll find that RB Tech has a lowering kit available for the S class for roughly $300. If you find out how to program the computer to lower a half inch please let me know. thanks
Old Aug 12, 2003 | 01:08 PM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
stephens in the E55 section was going to post pics of the DAS computer screens showing how to lower via computer. Haqven't seen them yet.
The trick seems to be getting the lowered settings to stick. My dealer tried to lower one, but it soon reverted to normal height. There apparently is a way to input new settings (voltages) for the electonic sensors to keep it lowered.
Old Aug 12, 2003 | 04:46 PM
jl88's Avatar
I've posted many times about lowering airmatic/ABC cars. There is the software solution and the hardware solution.
Old Aug 13, 2003 | 12:57 AM
shaggy982's Avatar
2000 Mercedes S500
jl, where abouts can you get the software in order to make the drop?
Old Aug 13, 2003 | 12:15 PM
99bmw740il's Avatar
2006 Mercedes E350 Sport
THose are sweet rims! Check with H&R i just got mine yesterday, puttin em on when I get my new wheels in 2 weeks.
Old Aug 13, 2003 | 10:24 PM
ajayz's Avatar
marta
Isn't the European setting lower? or something like that. Does this mean all of the S-classes in Europe are lower stock than here?
Old Aug 13, 2003 | 11:22 PM
EPower's Avatar
'05 E55
Re: any new info on lowering...
thanks
Shawn
Here is the link to some instructions on how to lower an E class. Don't know if the S is exactly the same, but they are all pretty similar w/ the airmatic. The sensors may be in a slightly different place. Did this myself in a couple of hours. All you need is a couple of washers and a Dremel tool. Real easy if you are looking for a drop up to 1.5 inches. Any more and you will need further modifications or the software fix. This is free, easy and works great. Check out the following...
https://mbworld.org/forums/showthrea...0&pagenumber=1
