W220 recent nightmare alarm related please help
As you can see I`m very fresh user of Mercedes S-class S320L W220, I have bought that car December last year, car is 14 years old so I can expect few things playing up, I had to change battery about couple of months ago as the old one was original, also when my clusters are everything of LCD screen disappeared and clock stopped displaying, I was after repairing these failures very soon but something new just come in which is really bad and I don`t know where to start.
Yesterday when I was at work alarm went off making horrible noise and police come over to see what happened-that was around 11am, I get back from work around 5.30pm so only heard siren making funny noise but battery in car was completely drain, ok then I opened the boot using my key, park my other car next to it and using starter cables connected batteries and I still couldn`t disconnect alarm at all - didn`t stop making noise, started car and it was making even worse alarm noise. I read in google that I need take the front left wheel off (I`m in UK so RHD), removed plastics, found siren and disconnect it using attached to it cable, siren was making silent buzzing noise. I thought ok then now problems are over - from now on I`ve got even bigger problem, went into a car, started engine and I can hear beep sound after 2 seconds and LCD changed from greenish colour to the red one ! of course LCD don`t display anything so I cannot see what problem is displayed. Also there is orange ABS warning light on the right side. I can drive the car normally, I can lift it, radio work, but this red colour on LCD put me off... Breaks do work as usual. Another thing which I noticed - I cannot regulate steering wheel any more, it can go only one direction, of course was unplugging battery, was trying with towing button which could not switch off the siren!
What would you think is at fault? Siren? If so why steering wheel don`t do job properly, there is some warning which changes display to red and ABS light is constantly on.
Today morning when I tried - battery was completely drained again even if I disconnected siren yesterday, I observed the car and wasn`t flashing or anything... After work have tried again - I`m just loosing myself here
Please please help me - I really want to become a happy S-Class user rather than miserable
Any ideas would be much appreciated
However, since the horn alarm is buggered why not switch it out anyways? Mine was an easy swap once you'd got the wheel off and the lining of the wheel arch.
What kind of problem did you had with your horn? You also couldn`t shut it up using the car key by pressing unlock?
no idea what happened to mine... anyone please?
You might try disconnecting your battery for a few minutes. Then reconnect it and see if some of the problems go away. Also, remember that when you disconnect the battery you have to go through the re-sync process which includes the windows, doors, sun roof top, etc.
Might help eliminate some of your lights that are on.
Any other suggestions? anyone ever had similar problem? Would you think that responsible bit is a horn?
cheers
I hope after I sort out that issue eventually my next posts will be in regards to nice bodywork fixture as there is a fair amount of rust on known places...
I have bought it as I always dreamed to own this particular S-class model...
Keith
Just disconnecting the siren did not stop the alarm power being used
You'll have to have your electronics sorted out
And I don't think hitting the "towing" button shuts off the tilt alarm
Was wondering how your car was driving when you removed the quote? How did you it was faulty? what it was doing prior to that?
Have you done any real research on your vehicle? The first thing pointed out in my research is that these machines are very susceptible to low/high voltage conditions. If your battery is flaky, ie unable to hold a charge, then your voltage will drop, current go high and subsequently fry electronics..........
So, firstly, is the battery drain due to the quiescent current being high (if I remember quiescent current is about 50ma) or is it due to a f*****d battery? So, either replace the battery with a new or known good battery and check the quiescent current and SEARCH out how to do that.
Tower
It's good that you replaced the battery (I hope for the proper size), but have you check the quiescent current? Have you checked the battery voltage first thing in the morning? A lead/acid battery whether gel or flooded, is nothing more than a reservoir for electricity. It stores it. Once you have depleted the reservoir, the lower voltage may be the culprit. So check it out.
A fully charged battery will show around 13.2 volts. A discharged battery will show 12.6 volts or lower. After your car has sat overnight, what is the voltage level of the battery (to check this, first thing in the morning, turn on the head lights and ignition for 10-15 seconds and then check the battery voltage at the battery. What do you get?)
New alarm siren turned up this morning as well, so having these two brand new parts, I have lifted Merc, took the wheel off, removed all siren, plugged new one in, connected everything, installed battery and... doing exactly same thing... alarm noise in on and I cannot switch it off, when clicking the unlock button on the remote it open the car but alarm noise does not want to go off, I have even thought that might be my battery in remote key getting faulty and took my spare set of keys which also cannot switch the alarm off so basically I have to disconnect siren.
Any clues at that stage please???
Has got red switch/latch/lock to remove mechanical key
Go to a Mercedes dealer and have the key fob checked.
Siren went off at the nighttime by itself on my 2005 W220 S500. It's located at the front wheel well at driver's side. I removed it and decided to take it apart. This is what I found. Check attached.
