Help with identification!
Old Sep 13, 2013 | 07:50 AM
Bigtaff's Avatar
S500 Lorinser
I have a late 2000 S500 of which the data card says it had a Nokia phone set up when new. All I have now is a cradle and no wiring. Is there any way of identifying which Nokia it had? The cradle is pretty small IMO, it looks more likely to take a clam shell style phone than the Nokia of that era but I've no idea if this is the case.
Old Sep 13, 2013 | 10:24 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
It might help a bit if you post a picture of the cradle.
Old Sep 13, 2013 | 01:35 PM
Bigtaff's Avatar
S500 Lorinser
OK, I've attached an image (I hope).
Old Sep 17, 2013 | 02:54 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
go in the back seat, under the vents facing you in the middle pop it open and see if wires are there then open trunk and see if hardware there, sometimes when you buy a used car, people pull things out to sell, then go on ebay buy replacement parts for the trunk then fine a bluetooth puck thats a very good option.
Old Sep 18, 2013 | 11:32 AM
Bigtaff's Avatar
S500 Lorinser
I have taken the cradle out and underneath, on the wiring loom, was a part number. Searched on google and, sure enough, this is the handset I am missing. Any idea what it is? http://de.picclick.com/TELEFON-NOKIA...046825454.html
Old Sep 18, 2013 | 12:20 PM
ibeforreal's Avatar
Just as corkshoppe stated you may be better off finding if you have the necessary wiring in place to add a bluetooth adapter instead of trying to replace the phone. However, if you do decide to go with the bluetooth adapter make sure it is compatible with your current cell phone.
Here is an example of what I'm talking about.
http://www.ebay.com/itm/MERCEDES-BENZ-Bluetooth-Adapter-Dongle-Phone-Cradle-Module-Interface-B67876131/141060212436?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D261%26meid%3D1377418475150348063%26pid%3D100005%26prg%3D1088%26rk%3D1%26rkt%3D5%26sd%3D200957536458%26
Old Sep 18, 2013 | 12:30 PM
Bigtaff's Avatar
S500 Lorinser
I did some Google searching, I have the Nokia 6091 install (or lack of). Reading a few posts by others, it seems the 6091 doesn't lend itself well to being upgraded?
Old Sep 18, 2013 | 02:51 PM
ibeforreal's Avatar
Here is one that might help.
http://www.ebay.com/itm/ViseeO-MBU3000-Bluetooth-for-Mercedes-with-original-Nokia-6150-6210-6310-cradle-/261289496393?pt=UK_In_Car_Technology&hash=item3cd6114f49
Magnificent New Mercedes-Maybach S-Class Revealed: 12 Things to Know
Old Sep 19, 2013 | 01:17 AM
Frank_S500's Avatar
SL63 (R230), CL500 (C215), SL55 (R129), CE300-24 Cabrio (A124)
Yes indeed. No easy upgrade possible. And only gsm 900.
Cheers, Frank
Old Sep 19, 2013 | 10:44 AM
corkshoppe's Avatar
Top Answer: 1
blue tooth is the only option!
Slideshow: Mercedes-Maybach has refreshed the S-Class with new lighting signatures, AI-driven software, and even more elaborate rear-seat luxury.
By Verdad Gallardo | 2026-03-25 18:01:51
