Ggetting wet
Old Sep 15, 2013 | 12:37 PM
starprint's Avatar
Mercedes s320 (w220)
Ggetting wet
Hi all,
Please could you help on a few issues on my car
My car heaters aren't blowing any air and as its getting ng cold really need to sort this, before giving it in I thought I'd post here.
I have noticed water in passenger footwell so opened bonnet and opened the grill on passenger side and drained water out. I have not noticed any more water around passenger footwell.
My car once started runs good and then into limp mode but runs fine - dosent go above 2,000 revs.
2 days ago car won't start unless I try 30 or so times
I really need some advice and likely issue with it
Thank you all and look forward to your replies
Old Sep 15, 2013 | 05:08 PM
tusabes's Avatar
Mercedes
The water damage has caused extensive electrical damage to your car. if you didnt pull the front and rear carpet the water travels in a channel straight back to the electronics under the rear passenger seat
Do you have comprehensive coverage on your auto insurance ? That should cover water damage
Old Sep 15, 2013 | 06:42 PM
starprint's Avatar
I know sounds silly but what kind of damage would you suspect it's caused and if it can be fixed what to do. I don't have that cover on my insurance. :|
Old Sep 15, 2013 | 08:18 PM
tower's Avatar
2002 s500
Hi starprint:
Rather than going through a long diatribe, try this:
https://mbworld.org/forums/s-class-w...ins-clean.html
I know that when I got my first W220, I could not make out the fuse chart identifying the lighting circuit on an electronic fuse. After more searching, it became evident that this electronic fuse was the main motherboard of the fuse boxes, and you have at least 3 in your vehicle. They are officially called SAM's, but having the front air plenum (the plastic box directly below the air vents between your hood and windshield) drain plug up with debris will force water to fill the plenum and spill into the cabin of the car. Once it overflows in the passenger side, it will flow under the rug to the back seat area and could effectively fry that SAM and other collateral damage. Better read and hope cause it can become expensive quickly.
Tusabes has called it right....
Old Sep 15, 2013 | 10:44 PM
tusabes's Avatar
Mercedes
Read that thread
Pull up your front and rear carpets
Take out the electronics and use a hair dryer to dry everything out
Only after everything is dry will you be able to tell what Damage is permanent
Stop starting the car , you are shorting everything out and causing damage
Old Sep 15, 2013 | 11:20 PM
just.andy6's Avatar
2000 mercedes-Benz s430
. Ohhh man, I feel your pain. It rained reallly hard out here in tampa fl, well long story short, the passanger ruuber on the door thing (sorry dont know what ts called) was broken and water came in through there. My sam, the one under the seat was flooded and my car won't start or preerty much do any thing. Ive read around and its a ridiculously expensive fix. Please let us know how thinks come out.. good luck.
Old Sep 15, 2013 | 11:58 PM
tusabes's Avatar
Mercedes
Just Andy , if you have comprehensive coverage on your auto insurance file a claim. Do it quickly before the evidence (waterdamage) disappears so they don't deny it and call it a mechanical problem
Old Sep 16, 2013 | 12:08 AM
just.andy6's Avatar
Im under my moms insurence since im in college and its cheaper. But I think I have something called liability or something. Does that work. I mean I heard since its considered natural disaster its covered?
Old Sep 16, 2013 | 02:24 AM
tusabes's Avatar
Mercedes
No - you have to have "comprehensive ". Ask your parents.
Liability coverage is only to fix the other persons car when you hit someone else and to pay for their injuries
Comprehensive coverage is for things like fire theft and water damage
Collision coverage is to fix your own car if you hit someone
You can have one , two or all three coverages , you need to look at your insurance bill or ask your insurer if you have comprehensive coverage
Old Sep 16, 2013 | 03:22 AM
starprint's Avatar
Thanks to everyone for their replies and advise. I'll start by drying everything out and keeping my fingers crossed. I'd have to get it fixed as insurance won't cover this. I will keep you guys posted and wish me luck
Thanks again
Old Sep 16, 2013 | 05:09 PM
starprint's Avatar
I have had the car towed in today, the guys here disassembled the seats and took carpets out, luckily water had not gone to the rear. After putting it on diagnostics he thinks it's the camshaft sensor?! I have ordered it and hoping this is it. He said alot of water was around this sensor?! Guys does this sound about right
Old Sep 16, 2013 | 06:48 PM
just.andy6's Avatar
Thank god, I called my insurance and it covers water damage. Just now the tow truck took my baby.... straight to the mb dealership down the road... oh Yeahh!
Old Sep 16, 2013 | 07:07 PM
starprint's Avatar
I feel for you Andy. Now what you going to do? Buy another?
Old Sep 16, 2013 | 07:51 PM
just.andy6's Avatar
No, im keeping mine.. ive grown attached to my s430... they're gonna fix her up. The SAM was flooded so thats gonna be replaced. Its all gonna be around 5grand to fix.
Old Sep 16, 2013 | 10:25 PM
babacee's Avatar
2002 Mercedes Benz S 500
Bumper Question
I figured you guys might be online at the moment to see this.
Different issue but i'll be glad to get some opinions. I have a 2002 S 500 and wanted to know when I buy a Bumper for 2003 S 500 if it will fit my vehicle. The bumper I want is made from fiber glass and it can be molded to fit. I want to get a second opinion from you guys and tell me what you think. If you know anyone that made this switch that will be awesome to get feedback.
Thanks in advance guys and I look forward to your answers.
By the way this is my first day as a member!
Old Sep 17, 2013 | 12:07 AM
tusabes's Avatar
Mercedes
No it will not fit without extensive modification
The hood and bumper of the 2000-2002 and 2003-2006 are different.
Your question is not related to flooding so start a different thread when you have an unrelated topic to discuss in the future
Old Sep 17, 2013 | 12:13 AM
tusabes's Avatar
Mercedes
You mean the crankshaft position sensor ? it is a very common failure item on these cars. It's in the engine compartment
There's a video how to change it here
http://youtu.be/KTTM3VeJuA8
Try it and see if it solves your starting issue
Be sure your drains are clear so no more water leaks into your passenger compartment !!
Old Sep 17, 2013 | 05:03 AM
starprint's Avatar
Yeah they are saying it could be the sensor as mentioned but it's coming Wednesday. hopefully it fixes her up. I'll keep you guys posted
Old Sep 17, 2013 | 03:00 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
buy used sams on ebay, waaaaay cheaper. easy to replace yourself
Old Sep 17, 2013 | 11:07 PM
just.andy6's Avatar
this is how the rear SAM looked when i removed the back seat....
Old Sep 17, 2013 | 11:57 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Can't see your picture Andy.
Old Sep 18, 2013 | 12:07 AM
just.andy6's Avatar
Its asking for a url.... how do I post it. I really want you guyd to see this.
Old Sep 18, 2013 | 02:26 PM
starprint's Avatar
Just to let you guys know my car is back in action!!!! It was the crankshaft sensor!! Thanks all for your advice and stuff. Got my baby back.
Only problem before this one is that it goes on limp mode sometimes especially after 10 minutes of driving or so. Anyone k ow what this could be
Old Sep 19, 2013 | 01:19 AM
just.andy6's Avatar
happy for you man... mines still awaiting approval from insurence to begin changing carpet, and checking for damages. i bought 16 new oem double platinum bosch spark plugs today. cant wait to get her back and instal them. im currently driving my moms expedition... YUCK! can you say 11mpg? jaja
Old Sep 19, 2013 | 04:16 AM
starprint's Avatar
Haha. Andy I'll pray for you specially . Trust it'll be ok.
I'm going to start a new thread maybe today regards to 2 other issues.
Limp mode and the heater blowers aren't working!!!
