too low front suspension
Old Sep 21, 2013 | 01:18 AM
saltyydogg50's Avatar
2001 s430
i changed the oil myself on a 2001 s430 trying to save some money in this difficult time, i jacked one side up when i lowered it, the front went all the way down,,, help!!!
Old Sep 22, 2013 | 10:50 AM
khanhtrinh671's Avatar
2007 R500 and 2007 Ml 350
With s class , I believe you have air spring leaks , when it leaks , you car will sagged down , or maybe air pump blow up , check the 40 amp fuse for air pump , find some leak around air sring connection or air line by spraying soap jix with water , my R500 recently down at the back and I hafe just convert air spring to conventional coil spring , it eirk perfect
Old Sep 23, 2013 | 02:29 AM
2001 s430
found the air leak only passenger side when the car is tilted, that is when i jacked one side, i wonder if it is normal, just had to wait a little while for the compressor to work and raised it back up, no repairs made, works fine no leak using the ramp, how much did it cost you to convert air spring to coil spring? just curious,,,
,,,thanks
Old Sep 23, 2013 | 10:19 AM
coil spring conversion
Once it leaks , it will never come bsck to normal , reason you dont see your car low when driving because the air pump works whenever started , however keep doing so will get more damage to the suspension system and ended with nasty repair bill , your air pump may overload as it tries to to balance , look for my detail info how to convert under R500 air spring conversion , the total cost for me is :$340 /pair OEM coil springs from MB , $250 /complete pairs of top and bottom retainers , $169 coil spring compressor , this is a special tool for MB , without it , there is no way to do and don't waste time to use conventional compressor , shoot me email if you need help , I am very happy with my conversion as it is forever good bye to sag down the car
Old Sep 23, 2013 | 10:26 AM
If you replace no matter what kind of spring , do it by pair as the other is very close to trash
Old Sep 23, 2013 | 02:22 PM
2001 s430
thanks for the info,,, the car is sitting outside and struts not leaking w/o the compressor/engine running though, drove it for a few days, nothing happens, am watching it though, keeping my AAA card,,, thanks
Old Sep 24, 2013 | 09:04 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
prolly what happened was, when you jacked it up the strut separated and when you lowered it back down it fit fine, but if you hit a bump you might here air leaking out, pretty much you will have to replace it.
Old Sep 25, 2013 | 04:21 AM
tusabes's Avatar
Mercedes
Lots of problems have been reported when lifting a s500 on a service lift . I forget the proper procedure is - I think you need to start the car before dropping it back down or something like that
Old Sep 25, 2013 | 07:06 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
same thing happened to me once with the S600 hydraulic suspension: Jacked up the left front, put a safety stand under the strut point of the link, and left it like that for 4 days.
When I used the jack to lower it, it went all the way down (not just the left front). I jacked it up to almost normal height and started the engine, it rose and has been fine since (even with further jacking for other jobs), and had been fine before with several jackings.
I call it an isolated event, but it points out the possible dangers if you don't use a safety stand.
Old Sep 25, 2013 | 09:04 PM
2001 s430
nice to hear that kraut56, how long ago has it been since that happened? and to all other remarks, its wonderful and i learned more from your comments, thank you guys,,,
