W220, 2001 s-55 AMG ABC suspension is sagging when parked
Old Nov 12, 2013 | 01:01 PM
Anthony Espana's Avatar
2001 s55 Amg
So i 've had my W220 for about five years now, im the second owner!
i dont want to get rid of it, but this suspension problem is getting old!
I park my car and and about twenty minutes later is starts sagging little by little.
Its pops right up when i start it.
Does anybody out there have any answers?
please help.
Old Nov 12, 2013 | 02:55 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
you have a leak, its on of the struts, if the back goes down first then its a rear shock. and vice versa. be careful when jacking up the car the strut might split in the middle, that will tell you which one is leaking.
Old Nov 12, 2013 | 04:18 PM
2001 s55 Amg
Thanks for the help, Should I go to the dealer or visit my local MBZ Auto shop?
How much does something like this cost?
Old Nov 12, 2013 | 04:23 PM
5280CLS55's Avatar
2006 CLS55 AMG, 2008 G55 AMG, 2010 Audi R8 V10, 2010 Ford Raptor, 2005 Porsche 911, 1966 Chevy II
Not cheap. My guess is about $1,500 a corner
Old Nov 12, 2013 | 05:28 PM
corkshoppe's Avatar
Top Answer: 1
arnott has for 450 a piece!
Old Nov 12, 2013 | 05:30 PM
5280CLS55's Avatar
I just had one done and I think the strut itself was like $900 and then install
Old Nov 12, 2013 | 05:32 PM
corkshoppe's Avatar
Top Answer: 1
nice ride 5280, it is sick!
Old Nov 12, 2013 | 05:34 PM
corkshoppe's Avatar
Top Answer: 1
both rides... sick sick.
Old Nov 12, 2013 | 05:51 PM
5280CLS55's Avatar
Thanks man!
Old Nov 13, 2013 | 03:43 PM
s5benzo's Avatar
W221 2013 S550 Rwd, W221 2010 S550 Rwd
Anthony when a vehicle with abc suspension drops it can also be the valve blocks . These metal blocks have solenoids on them with hydraulic fluid passing through . Any dirt or contamination can cause leaking valve block . The solenoids have o rings which can also deteriorate over time. Theres a YouTube video on cleaning the valve and replacing o rings. Then you will see what I'm talking about . No sense in replacing struts if that's not the problem ,abc parts can be very expensive . Arnott is a great replacement probably better than oem. First be sure what the problem is be4 you start throwing parts . Goodluck , Gill
Old Nov 14, 2013 | 09:55 AM
corkshoppe's Avatar
Top Answer: 1
s5benzo, you are correct. abc in a s430. still a mystry!
Old Nov 14, 2013 | 11:46 AM
s5benzo's Avatar
Its rare but I have seen 430's and 500's with abc. It was an option so your going to see airmatic a lot more . To be honest abc is not a bad system , there are a lot of issues with it . I think preventative maintenance is the key. Of course any system that gets old is gonna leak and have worn out hoses etc . Running the system dry is probably number one abc pump killer. Fresh fluid and filters , taking care of leaks before hoses burst will probably prolong your system .
