Radio Antenna
Also does the key fob work off thew radio antenna or soes it have its own antenna.
As always all comments and help is appreciated.
Number 90 in the file attached
Pointing the key fob at the sensor in the door handle if using the Infrared transmitter in the fob and is totally separate form the RF transmitter.
There are separate amplifiers for each band ( AM, FM, Remote control and TV on EU models ) Reception problems ( primarily in the AM band ) have been attributed to using metallic tint film on the rear glass. If its just FM that's dodgey than suspect that amplifier.
If you have the metallic/reflective tint on the rear glass it is probably your culprit if the AM reception is the issue. You will hear a whine or hum in your speakers that coincides with the engine speed. If it is the FM band that is the problem it may be the amplifier under (above?) the headliner.
The key fob works on its own receiver and not the radio receiver. Also, pointing the fob at the door handle utilizes the infrared receiver in the door handle itself and is not RF. This is used to raise/lower the windows/moonroof from the outside of the vehicle.
I am still a little confused about the fob antenna. My fob works with the rf in the door handle but doesn't work with its antenna. I am assuming that the fob antenna is part of the rear window antenna which is shown in the pdf as 90. Am I still on the right track?
If I am on the right track then which part of 90 is the fob antenna?
As for which part of the rear roof amplifier is responsible for the key fob reception.... sorry, MB only lists one part number for the entire assembly and trying to get engineering tech info/specs for MB parts is nigh on impossible.
I am still dumpster diving into WIS's dark corners trying to pull out info on some other stuff, I MAY trip over a wiring diagram, may not, will let you know.
afterthought: Have you replaced the fob battery? Cheap test.
I'm wondering what a job it is to pull the headliner down and inspect. Are there any secrets on pulling down the headliner?
http://www.benzworld.org/forums/w220...m-key-fob.html
http://www.benzworld.org/forums/w220...m-key-fob.html[/QUOTE]
Second chapter up on GPS now..same link.. still a work in progress, so thread still closed for a bit.
