Sat Nav W220
Old Feb 5, 2014 | 04:43 PM
starprint's Avatar
Mercedes s320 (w220)
Sat Nav W220
Hi People.
I know started another thread but have many questions. Hope that's good with you people.
How do I know I have the Sat Nav option in car. I don't want to buy the CD without knowing that's what will activate it.
Currently it says that Insert Navi CD.
Wait your replies people
Old Feb 5, 2014 | 08:00 PM
tusabes's Avatar
Mercedes
All USA w220 have nav
Note that if there is anything wrong with the system just installing the cd won't make nav work .
Old Feb 6, 2014 | 12:30 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Just buy a single cd off of ebay and slide it into the slot on the command to make sure it is working before you go out and buy a whole set.
Old Feb 6, 2014 | 06:07 AM
starprint's Avatar
Mine is the UK Version.
I have heard it is a NAV unit in the boot?
is this right?
Old Feb 6, 2014 | 06:48 AM
lganski's Avatar
2006 S430 4Matic
In US versions the nav unit is in the boot on the left hand side. There should be a door that gives you access to it. If it is not there you most likely don't have one.
Old Feb 6, 2014 | 06:49 AM
lganski's Avatar
2006 S430 4Matic
It will be with the CD Changer.
Old Feb 6, 2014 | 08:50 AM
wallyp's Avatar
2003 S500 2007 GL450
It always helps to give the info on the car, as things vary with model year and market. The earlier USA W220 cars use multiple CDs in one of two versions, inserted as needed in a slot on the Command Unit. Later (2004 and up) cars use a single DVD.
Since your Command Unit appears to be asking for a CD, you probably have an earlier car, and you probably have a nav system. I know of no way to tell whether it works or not without inserting a CD from the proper version.
Old Feb 6, 2014 | 05:33 PM
vmystikilv's Avatar
Range Rover
Um, I have nav , I don't remember seeing anything in the boot .2002
Old Feb 8, 2014 | 04:02 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
2004 are dvd and they are in the trunk, pre 2004 anr at the unit. and cd.
Old Feb 8, 2014 | 04:09 PM
Fraser's Avatar
A Mercedes obviously!
As long as your car doesn't have this you have nav. In the UK COMAND was an option on the early S280s, S320s (and CDIs) and the S430s. It wasn't until you got to the S500 that it was standard.
Old Feb 8, 2014 | 07:19 PM
tusabes's Avatar
Mercedes
Wow that's an ugly console
It just screams something is missing
