'04 S55 amg ABC pump changed. Cricket noise now
Old Feb 14, 2014 | 09:01 PM
holycowe's Avatar
Just have the tandem abc pump changed yesterday along with both front and rear accumulators. Today I've noticed a very weird noise come from the pump area (99% sure from there). It sounds like cricket, anyone let me know if it's inside the pump making that noise or it's the pump pulley?
URGENT!!,!
Old Feb 14, 2014 | 09:08 PM
holycowe's Avatar
Also, the inside of the idler pulley. I found this plastic ring hanging loose! Look like it fell off the inside of the pulley.
What should I do? Have to change idler pulley ASAP???
I'm on my iPad. I don't know how to add pic.
Old Feb 14, 2014 | 09:31 PM
holycowe's Avatar
This's the plastic ring broke off from the idler pulley
Attached Thumbnails '04 S55 amg ABC pump changed. Cricket noise now-image.jpg
Old Feb 14, 2014 | 10:05 PM
tusabes's Avatar
Mercedes
Sounds like the pulley
Take it back
Old Feb 14, 2014 | 10:17 PM
haoz129's Avatar
MB 2003 S600. Volvo 2003 XC70.
If over 60kmiles, time to change belt, tensioner and pulleys.
Old Feb 14, 2014 | 10:25 PM
holycowe's Avatar
Did change the belts couple years ago.
She has 108k miles. Might have to change tensioner, idler and abc pump pulleys
But since yesterday, inside the car smell oil as well
Old Feb 14, 2014 | 10:28 PM
holycowe's Avatar
Any chance it's from the pump if its sound like that?
I hope it's the pulley
Old Feb 15, 2014 | 01:25 AM
holycowe's Avatar
After I get home, that noise goes away at idle. But I can hear it when revving the engine.
Old Feb 15, 2014 | 07:47 PM
wallyp's Avatar
2003 S500 2007 GL450
One fast and free check can be made by spraying a fine spray of water on the inside of the serpentine belt with the engine running. If the noise goes away or changes noticeably, it is almost certainly from the belt.
You can also use a mechanic's stethoscope to listen to each of the belt-driven units and idler or tensioner pulleys. The stethoscope, which has a long metal rod that is touched to the non-moving parts, will let you hear a failing bearing or unit. Use great care to avoid moving parts and the belt! They are inexpensively available at Harbor Freight or most auto parts stores.
Old Feb 15, 2014 | 09:13 PM
holycowe's Avatar
Thanks, I sprayed some wd40 on it and it went away for few seconds and it come back. Hopefully, it's the tensioner (right next to the p/s) making that noise. Since all the pulleys are stock still, I'll replace the belt, tensioner and idlers (the plastic one already broke) on Mon.
Old Feb 17, 2014 | 10:59 PM
holycowe's Avatar
I got it fix! Member OKclass, had the same noise, he changed the belt and the sound dissappear.
Since the plastic idler cracked and the tensioner never been changed. I replaced the tensioner, both belts and both idler pulleys. Everythings good.......for now
