Command system problems
If I were you I would remove it, find the 12 volts power pin and ground and keep powering it up on the bench until you figure out if it has the same symptoms. OR
read this thread that suggests its the AGW module.
http://www.benzworld.org/forums/audi...boot-w211.html
Be mindful that you could in fact have two modules that have failed and that can trick your testing. When you isolate modules from the ring, try and remove as many as possible. You only need the COMAND and the AMP to get audio when using the radio as a source.
Then add back one module at a time. You make have to turn off and back on the COMAND and ignition to test the changes before you hear any sound.
