2004 S600 -- Take car with75k miles with no maint records or 100k with maint records?
Not the documents are any guarantee. Use your nose and tread carefully.
Nick
All in all, the higher mileage may be the better deal.
Take the one with good records over the unknown.
1. Changed out coil packs plus plugs, $3,000
2. Changed tranny fluid
3. Changed ABC fluid and filters
4. Changed Brake fluid
There are MANY maintenace items for this car. If you can't find the above, RUN Forest Run
Check over ALL service reords. If the car has none, then I would run, LOL
Neither are going to have coil packs. It's not a maintenance item and if it ain't broke they won't fix it.
The one with records has all the standard items done when presented for a and b service at a dealer with no declines. So 2,3,4 would be done only if it's in the maint manual. Unfortunately the s600 has a special maint supplicant that is not on mbusa.com
