Is correct oil spec for 2001 S600 W220 0W40 Mobil 1, please?
Old Mar 23, 2015 | 09:33 AM
high123bid's Avatar
01 S600
Is 0W40 really correct? I have paid to have the oil changed up until now but I want to start doing it myself since they pump it out from the top anyway and since the oil filter is on top of the engine. Best regards, Bo
Old Mar 23, 2015 | 10:55 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Bo I have been using Mobil 1 0W40 for years on my Mercedes. It will take about 8.5 quarts. However, I always put in 8 quarts, run it a couple of days and check again and replenish if necessary. You can buy the Mobil 1 0W40 at Walmart for less than $25 for the five quart container.
I also use the vacuum process since I have seen the dealers do it.
Old Mar 23, 2015 | 11:19 AM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
Interesting fact:
My factory owned dealership does not use or sell Mobil 0W-40 anymore, only 5W-40 (as per their MB approval specs, which I reviewed with them to be sure).
Old Mar 23, 2015 | 06:19 PM
ibeforreal's Avatar
According to the factory approved service products the following oils are approved in MB Sheet 229.1/229.3 for the S Class gasoline engine:
1- Mobil 1 SuperSyn European Car Formula.......OW-40
2- Castrol Syntec...........5W-40
3- Quaker State Full Synthetic European Formula......5W-40
4- Pennzoil Synthetic European Formula.....5W-40
5- 76 Pure Synthetic Motor Oil.....5W-40
It is up to you but I would just buy the Mobil 1 0W-40 European formula which meets the MB specs. Buy the European Formula.
Attached Thumbnails Is correct oil spec for 2001 S600 W220 0W40 Mobil 1, please?-mobil-1-oil.jpg   Is correct oil spec for 2001 S600 W220 0W40 Mobil 1, please?-mobil-1-european-formula.jpg
Old Mar 23, 2015 | 11:48 PM
high123bid's Avatar
01 S600
Thank you for some great answers
I will head to Walmart to get some oil tomorrow. Best regards
Old Mar 24, 2015 | 03:33 AM
cybertronicify's Avatar
2003 S430, 2014 E350
Keep in mind, you have a S600 which requires more oil. 9.5 Quarts i believe. I too have been using 0w-40 Mobil 1 for my S class. It works great!. For the M137 engine i dont think theres an oil dipstick, and you shouldn't trust the electronic measurement either. Siphon the old oil out from the filter port and put in the exact amount plus a little bit more, as the engine will burn the oil. But its best go buy an oil dipstick from Mercedes.
Old Mar 24, 2015 | 09:48 AM
kraut56's Avatar
You are better off underfilling by 1 qt, the MFD will tell you when when more is needed.
Do not overfill!
Old Mar 25, 2015 | 01:37 PM
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
I use the OW 40 from mobile one is my s 430 for the past 2 years and ive never had an engine problem with the car whatsoever , I also get it cheap at walmart
Old Mar 25, 2015 | 02:13 PM
Do not overfill!
kraut56, underfilling by a quart is too much. You should replace whatever you siphon out if you dont know he last oil change time.
Old Mar 25, 2015 | 09:55 PM
kraut56's Avatar
One qt. low is not going to hurt nothing, but, overfilling will.
