stick missing from oil dipstick
Old May 17, 2015 | 06:53 AM
MikeKerr7's Avatar
S-series 2003 S500 4matic
Purchased a 2003 S500 and am getting around to fixing many things. Went to check the oil yesterday and discovered no stick on the dipstick. Worried where the stick may have gone? All that was present was a plunger to seal the dipstick opening.
Could the stick have dropped partially in the oil pan?
Old May 17, 2015 | 12:22 PM
wallyp's Avatar
2003 S500 2007 GL450
When I bought my '03 S430, the top of the dipstick was broken off. I just bought a replacement.
I would suggest that you buy a replacement and try to insert it - if it goes in OK, don't worry about it.
Old May 17, 2015 | 11:02 PM
babyman1737's Avatar
2005 CLK500 cab, 2004 S600 designo mocha
I thought these cars didn't come with dipsticks, and that the oil was checked via the dash by oil level sensor. At least I know the S600's were this way.
Old May 18, 2015 | 01:55 AM
MB-Dude's Avatar
'96 SL600, '05 S55 AMG, '06 C230
I, too, was amazed that my newly acquired S55 didn't come with a dipstick. But I found a fabulous - and perfect - dipstick at the local wrecking yard. This post has the details...
https://mbworld.org/forums/m113-v8-k...tick-m113.html
Cheers,
Jeff
Old May 18, 2015 | 03:17 AM
cybertronicify's Avatar
2003 S430, 2014 E350
My 2003 S430 came with a dipstick from the factory. However my friends E500 doesn't have a dipstick. I checked the oil on a 2004 S500 and it had a dipstick.
Old May 18, 2015 | 10:51 AM
lganski's Avatar
2006 S430 4Matic
These vehicles do not come with either a tranny or oil dipstick. If you have one it was either purchased with the car or an aftermarket item.
Old May 18, 2015 | 01:46 PM
Most of the non 4Matic versions have the dipstick, however the v12s and the 4matics or kompressor series never has a dipstick. I'm not sure what Mercedes is doing here, since the onboard computer isn't very accurate.
Old May 19, 2015 | 05:56 AM
MikeKerr7's Avatar
I can't get the on-board computer to display the oil level. Ordering a disptick on Amazon.
Old May 19, 2015 | 01:27 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
My dipstick came with the car from the factory. I don't know how they pick and choose which cars to include the dipstick.
Old May 19, 2015 | 02:45 PM
To get the computer to show oil level, you need to turn the key to the first position (only SRS light should be on) Use the steering wheel buttons and navigate to the TOTAL ODO and TRIP ODO page. Press the "R" button 3 times and you should see a voltage pop up. Use the up and down buttons to scroll through the displays until you hit a page with your VIN number. Turn the key to the second position. LIGHT CHECK MODE. Wait a few seconds and the OIL LEVEL should show a number.
BTW i don't trust that oil meter at all. My dipstick says max, the computer says 6.9 Qts. My car takes 8.5 Qts. Theres no way im 1.6 Qts off. Been driving the car since and no problems.
