Radiator DIY
Old May 30, 2015 | 10:59 PM
Fried Chicken's Avatar
2005 S500 Designo
Radiator DIY
I'm looking to do the radiator on the W220 either tomorrow or Monday to fix a leak. I looked for a good DIY, but neither youtube, nor the various Benz forums provided an answer.
I have all the tools, hoses, radiator parts I need, now all I need is the knowledge.
My main concern is the Transmission lines.
Will I have to top off the ATF fluid? Are there any special concerns with the ATF fluid?
Many Thanks!
Old May 31, 2015 | 03:04 AM
MB-Dude's Avatar
'96 SL600, '05 S55 AMG, '06 C230
If memory serves, and depending on your specific model, there may be a separate transmission cooler. If you do have to disconnect a transmission line, you'll only have to replace a small amount of ATF; certainly not quarts of fluid. If you are concerned, measure the transmission fluid level before replacing the radiator and after. Top off as needed.
As for the ATF itself, it should be red in color as opposed to blue for newer models. IMHO, for what little you would need to replace, if any, grab a quart of good quality ATF at your local auto parts.
Cheers,
Jeff
Old May 31, 2015 | 04:50 AM
VMAX7's Avatar
2000 S430, 2000 S500 Both Brilliant Silver!
https://mbworld.org/forums/cl-class-...l500-s500.html
Old May 31, 2015 | 02:12 PM
2005 S500 Designo
This is excellent, thanks!
Old May 31, 2015 | 03:01 PM
VMAX7's Avatar
Good luck! Took me a few hrs taking my time last year, not hard.
Old May 31, 2015 | 03:10 PM
2005 S500 Designo
I just did a quick look on alldata and they put a note to seal the transmission oil lines. Is this absolutely necessary, and if so how do I seal them? Rubber Plugs or something?
Old May 31, 2015 | 03:57 PM
VMAX7's Avatar
I didnt do any of that, just unplugged them and placed them to the side. Make sure no dirt gets in the line!
Old May 31, 2015 | 04:46 PM
2005 S500 Designo
Cheers,
Jeff
I can't find where to A. check the transmission fluid level, B. Refill the ATF fluid.
How can I check the ATF model for the car? I fear I might have the 722.9, which is a ***** as I understand it?
I don't want to risk running low ATF fluid out of inability to measure/refill the Transmission fluid. This job may have to be delayed.
Old May 31, 2015 | 07:13 PM
VMAX7's Avatar
Buy a transmission dipstick tool from ebay if u have a long black dipstick tube at the rear passenger side of the motor.
Old May 31, 2015 | 07:52 PM
2005 S500 Designo
Nope, pretty sure it doesn't exist.
I have the 722.9 7G tronic transmission.
The hubris of mercedes "Sealed Transmission".
I think I'm going to do the radiator with the Transmission Fluid flush. I bought a $4 siphon pump which should do the job of the mercedes 7g tronic prototype pneumatically powered device.
Old May 31, 2015 | 11:56 PM
VMAX7's Avatar
I dont recommend tranny flushes. Only a simple drain and fill will suffice.
Old Jun 1, 2015 | 01:27 PM
Welwynnick's Avatar
2006 S600
Very very important that you get the tranny fluid level right.
Dipstick is a must. Peculiar thing to use; doesn't go all the way in.
You have to measure the level after 20-30 miles preferably fast running. Car on level ground, and test with the engine running in neutral.
Nick
Old Jun 1, 2015 | 01:42 PM
2005 S500 Designo
Nick
The 722.9 doesn't have a dipstick tube.
Old Jun 1, 2015 | 02:40 PM
Welwynnick's Avatar
2006 S600
Ah, never had one of those. Still need to get the level right, though. I think you fill the tranny pan from underneath, and its full when it overflows.
Nick
Old Jun 1, 2015 | 04:30 PM
VMAX7's Avatar
The way I figure out the fluid level is after a drive and the car has been warm and up to normal temps for at least 20 mins, I make sure its on level ground, put her in park, wait ten secs, put her in reverse, wait ten secs, put her in neutral, wait ten secs, put her in drive, wait ten secs, put her in neutral, wait ten secs, put her in reverse, wait ten secs, put her in park.
Then make sure the dipstick is TOTALLY CLEAN and free from lint and debris, slide it down the dipstick tube slowly until it feels it cant go any lower, it should be sticking out maybe 10" (inches) I think.
Pull it out and get your level.
Old Jun 1, 2015 | 05:46 PM
Welwynnick's Avatar
2006 S600
That's when you have a dipstick!
Old Jun 1, 2015 | 05:47 PM
VMAX7's Avatar
Yup lol
Old Jun 1, 2015 | 08:54 PM
2005 S500 Designo
Oh god I've been looking at the 722.9.
THE STORY OF THE HUBRIS OF MERCEDES!
The story begins when for political reasons a 7 speed transmission seems like a good idea. Then mercedes sucks the cumulative dick of the automotive industry by blindly jumping on the bandwagon of "sealed for life transmission". Then, because they are mercedes, and surely they know what they're doing, they don't include a dipstick, or in fact even a dipstick tube! Because they are MERCEDES! and they know what they are doing!
As it turns out they were wrong. Very wrong. In fact, not only did they determine their transmission needed a flush at 40,000 miles, the fluid level was incorrect from the factory to begin with! Now with any other transmission both of these problems would be easily solved with a dipstick tube. Just drain it, use a funnel, and refill. Measure with the dipstick appropriately, then be happy.
But no. In fact what you need to do now, is replace the entire transmission oil pan while keeping the vehicle raised and absolutely level, use a special mercedes tool to violate the new pan, fill the system, then *while the car is raised*, start the engine, run through the gears, hook up the STAR diagnostic computer, use your special tool and keep violating the transmission, ensure the temperature is exactly 45 °C (not sure how the hell you do this, what if it's too high or low? Maybe bring ice?), remove the mercedes violator, and let the excess $20/liter oil *get wasted* until the appropriate level is achieved. If it's not continue mercedes violating, remove the violator, and see if the appropriate level has been achieved.
Then wonder why BMW took the #1 spot.
Old Jun 1, 2015 | 08:56 PM
2005 S500 Designo
I'm not bitter at all.
Old Jun 1, 2015 | 08:59 PM
VMAX7's Avatar
Thats unacceptable. Ill be sure to avoid that box!
Old Jun 1, 2015 | 09:03 PM
2005 S500 Designo
Mercedes, in their infinite wisdom, replaced a $4 funnel with this:
