Car takes 5-10 seconds to start
Old Sep 8, 2015 | 02:11 AM
cybertronicify's Avatar
2003 S430, 2014 E350
My car takes 5-10 seconds to start sometimes. In the past 3 months. It has done it twice. What could be the problem? It just cranks as if nothing is happening, then suddenly it starts. Got a new battery 5-6 months ago.
Old Sep 8, 2015 | 12:14 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
Check the fuel pressure at the injector rail schrader valve.
Old Sep 8, 2015 | 06:01 PM
tusabes's Avatar
Mercedes
Might be a crank position sensor getting bad although they are usually an all or nothing
Start /no start symptom
Old Sep 8, 2015 | 09:18 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
+1 on the CPS.
Old Sep 10, 2015 | 07:37 AM
MikeKerr7's Avatar
S-series 2003 S500 4matic
Change the fuel filter for $40 and thank me later. If it was a sensor, it would be cam position sensor if not starting when cold, crank position sensor when not starting when hot.
Just change the fuel filter, kruat56 gave great guidance, but if you don't want to diagnose, replace the filter, I bet you will quickly fix your issue.
Old Sep 10, 2015 | 10:32 AM
I see 52 PSI at the schrader valve. Is that a bit high? It should be 40 PSI I think. The car is fine when it's started, WOT no problem.
Old Sep 10, 2015 | 10:33 AM
Is the fuel filter replacement hard? I don't have that much time on hands right now.
Old Sep 10, 2015 | 10:34 AM
The car only had a hard crank twice. I can't reproduce it. Both times were at my work parking lot.
