Air matic level sensors questions
Old Dec 6, 2015 | 02:36 PM
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
hell o gentlemen
yet another issue with my 2001 s 430
i recently replaced some more control arms in the front end upper and lower
however drivers side air strut is higher than others and is causing the car to pull to the right and has worn out my brand new rear right tire in less then 30 days
i fear the tire will blow any day , is there any method of getting both sides in the front evan ? i have tried adjusting and readjusting them but to no avail
please let me know if this is something you have solved before
i live in new england and the car needs to drive straight if im going to make it through the snow and ice this winter
thanks in advance
Old Dec 6, 2015 | 07:30 PM
_Ryan's Avatar
2004 S600 Biturbo
Mess with the level sensors is the cheap way to do it, as long as everything is working properly. Sometimes after changing components you need to re-level the car with Star/DAS which is the proper way to deal with it.
For super cheap and hack job way, you can either add washers to the level sensor to lower the car or you can bend the linkage to raise the corner.
I think you have other issues if you wear out a tire in 30 days.
Old Dec 7, 2015 | 05:29 PM
Benzman33's Avatar
2024 GLE 350
Didn't you sell the car Luckdragon?
Old Dec 9, 2015 | 01:59 PM
Benzman33 i sold the other mercedes s 430 this one with the issues of the airmatic leval is my own personal car
Ryan adding a washer would lower the airmatic if i put it where on the sensor where it connects to the upper control arm ?
Old Dec 15, 2015 | 12:50 AM
Anything on this ???
Old Dec 15, 2015 | 11:39 PM
cwallens's Avatar
2001 S500 W220
I would recommend that you go to a shop with a STAR diagnose system and get the suspension level unit adjusted correctly. Did you do an alignment after you changed the control arms?
Old Dec 17, 2015 | 09:15 PM
Yes had an alignment done at firestone , made it worse any idea what it would cost to have it leveled out by star diag ?
Old Dec 18, 2015 | 01:42 AM
tusabes's Avatar
Mercedes
Always get your alignment done at a real mb dealer
They do it right and its. Not that much more expensive
Old Dec 18, 2015 | 09:31 AM
cwallens's Avatar
2001 S500 W220
I had mine done at an independent shop and I paid $80 for it
