2001 s600 head bolt specs
2001 mercedes s600 amg
I recently purchased 2001 s600 with bad oil cooler.
when getting into this job, I noticed cams were in bad shape, purchased another used motor in better condition, still replacing oil cooler while engine is out. QUESTION ... dose anyone know the torque specs on head bolts.
also the crank bearing and cam holders torque specs
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
You need the special cam holding fixture while undoing and retorking the sprocket bolts; the chain is not designed to hold it while torquing.
The head bolts must be measured before re-using; they are "stretch" only, not "yield".
Pinkster can provide you with the complete WIS for this job, you must folloe the steps implicitly.
Been there, done it!
Well, having done this job 8 or 9 years ago, I advise you to first get the WIS, and follow it to the letter!
You cannot do without it.
You can search my experience here and the other forum under my nick.
At least 40 hours+.
You need a lot of tools.
Good luck!
At least 40 hours+.
Good luck!
RTChoke (11-27-2022)
