ABC Fluid
Old Mar 13, 2016 | 10:15 AM
Just600's Avatar
2002 S600
ABC Fluid
The fluid in the reservoir closest to the front of the car is low. What type of fluid do I need to put in?
Old Mar 13, 2016 | 10:37 AM
tusabes's Avatar
Mercedes
Pentosin. Chf11s
Sold at many auto parts stores
Old Mar 13, 2016 | 10:41 AM
Just600's Avatar
2002 S600
Originally Posted by tusabes
Pentosin. Chf11s
Sorry it's a 2002 s600, will that fluid still work? Thanks!!
Old Mar 13, 2016 | 10:42 AM
mcguirja's Avatar
Mercedes SL63 AMG; Mercedes E63 AMG S 4matic; Mercedes C43 AMG; Mercedes S Class, Mercedes GLK
You need to use Pentosin. I recently flushed my system and purchased it from Amazon.
Amazon.com: Pentosin 1405216 CHF 11S Synthetic Hydraulic Fluid, 5 Liter: Automotive Amazon.com: Pentosin 1405216 CHF 11S Synthetic Hydraulic Fluid, 5 Liter: Automotive
Old Mar 13, 2016 | 10:45 AM
mcguirja's Avatar
yes
Also, you may want to really clean up the area around the reservoir, the system is very sensitive to any kind of dirt particles.
Old Mar 13, 2016 | 10:51 AM
Just600's Avatar
2002 S600
Originally Posted by mcguirja
yes
The cap was loose, and it looks like the fluid leaked out. Do I need to use anything in particular to clean it? Thanks again for the help!!
Old Mar 13, 2016 | 10:56 AM
mcguirja's Avatar
That's a drag, hopefully nothing got in while it was open. Any kind of cleaning material is fine, but more important to make sure the seals/caps on the reservoir are on really tight while you're doing it so nothing gets in.
Old Mar 13, 2016 | 12:35 PM
compaddict's Avatar
2016 S63, 2013 SL63
Or an accumulator popped and blew out the fluid.
Old Mar 13, 2016 | 12:53 PM
Just600's Avatar
2002 S600
What does that mean??
Old Mar 13, 2016 | 01:11 PM
compaddict's Avatar
2016 S63, 2013 SL63
Our ABC cars have nitrogen filled accumulators and when they fail they blow fluid out the reservoir. Mostly easy to replace and certain ones are more likely to fail. Check out the encyclopedia. Lots of info.
Old Mar 13, 2016 | 02:10 PM
mcguirja's Avatar
Here is a thread that includes a schematic for the ABC with different Accumulators/Pulsation Dampeners. I just had to replace the pulsation dampener on my SL63 and I flushed the system at the same time.
There are a number of threads on this if you do a bit of searching.
https://mbworld.org/forums/cl55-amg-...umulators.html
