03 s600 throttle body issue
Old Apr 4, 2016 | 10:32 PM
Demon954's Avatar
Mercedes e55 amg
Hi to everyone,
I just purchased a 2003 s600tt with 94k miles on it from a dealer.
I test drove the car and fell in love with it. I took the car for about a good 20 min, let it rip a little just to fell the power, everything was fine no codes and so I purchased it.
On my way home all the sudden the car started to shake and the ESP malfunction came on. Took it to a local shop to connect to a computer and they told me it was the throttle body actuator.
I spoke with a service rep from Mercedes, he recommended that I should open the throttle body and try to clean with brake fluid.apparently they r known for this throttle body issue. Just was wondering if anyone had an issue like this and how did it get resolved?
Old Apr 5, 2016 | 01:39 AM
tusabes's Avatar
Mercedes
Clean it with brake cleaner, not brake fluid
Old Apr 12, 2016 | 11:30 PM
Demon954's Avatar
Mercedes e55 amg
Correct Tusabes, brake cleaner not fluid. So I tried to clean and still same thing. Shaking at low rpms, ESP light and safe mode.
I have no more patients with this and decided to buy a used one since a newnone cost $1600. Will upstate when it comes
Old Apr 13, 2016 | 03:11 AM
engindin's Avatar
2002 S320L
Is there any relation between ESP and throttle body actuator?
Old Apr 13, 2016 | 09:11 PM
Demon954's Avatar
Mercedes e55 amg
Don't know myself, but what my local shop told me is that the car has a throttle body actuator problem and the computer is making the car go to ESP safe mode from improper throttle reading. How true is this I have no idea
Old Apr 15, 2016 | 06:22 PM
Demon954's Avatar
Mercedes e55 amg
Hi everyone again
Update on the issue
Just changed the throttle body actuator with same part # started the car, still same issues.
Went to my local shop to clear the codes, no luck there
Car symptoms= when starting car is shaking, press on the gas seems to be fine and 7 sec later the ESP light goes on with pre-safe inactive
Read the codes it was c1041-002 can message 47-5
Also showing me the exact throttle body actuator code also
I've changed the actuator so I know nothing is wrong with it
I've checked all the fuses, everything seems fine next step thinking about replacing the ESP module
Need help!!?
Thanks again
Old Apr 21, 2016 | 05:48 PM
Demon954's Avatar
Mercedes e55 amg
Update guys,
Just changed my ESP module and still the same problem.
Anyone else have any ideas? I would really appreciate
Thanks again
Old Apr 21, 2016 | 06:28 PM
MacVidMB-V8's Avatar
W209, W124
Was it checked on "a computer" or SDS?
Why can't you take back to dealer?
Old Apr 21, 2016 | 09:30 PM
Demon954's Avatar
Mercedes e55 amg
It was checked on star computer.
Bought the car as is
Old Jan 4, 2026 | 12:46 AM
globalauto's Avatar
s320
Did u ever fix it ? Did u buy the car in Slidell Louisiana and its silver
From RB Premier Auto Sales ?
I have a car that you just posted the exact same problem !
