Where do I install B67875855 Blue Tooth Adapter on 2004 S430?
Old Aug 2, 2016 | 12:37 PM
hififan's Avatar
2004 mercedes s430 4matic
Hello
I recently purchased this for my Mercedes S430. I found a fuzzy video on You Tube for the E class. Where does this connect on the S430? I know it is in the center console but is it the lower bottom or in the upper shelf? Has anyone installed this on an S Class? As you may tell, I can sure use some guidance and instruction.
Thank you
John
Old Aug 2, 2016 | 03:42 PM
Jack_88's Avatar
2018 C300
In my CL, the upper shelf has a false bottom, held in with screws below. If the S-class is similar, it's quite an easy install. Take out the false bottom, make sure there's a place for the cord to come through and reassemble.
Old Aug 2, 2016 | 03:47 PM
kyosuke's Avatar
1999 e320 ,2006 AMG S55
i wish i had a straight answer for you but look here
http://www.benzworld.org/forums/audi...ades-plug.html
seems like you got the module,do you have the puck as wel ?
Old Aug 2, 2016 | 04:58 PM
Jack_88's Avatar
2018 C300
This is what mine looks like, I'm not sure what the S-class looks like under the armrest cover.
http://www.benzworld.org/forums/c215...h-install.html
Old Aug 2, 2016 | 05:00 PM
hififan's Avatar
Thank you for the responses. Jack 88, I will remove the "floor" from the upper console tomorrow. Kyosuke, I am under the impression that this is the only part needed from other posters on MB sites. If I'm wrong, it will be another surprise. Thank you both
Old Aug 3, 2016 | 09:46 AM
hififan's Avatar
Hello Again my thanks, I installed the puck in less than a half hour. The blue tooth device recognizes my phone; however command does not. Off to some new research on this matter. Thank you
Old Aug 4, 2016 | 08:26 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
This is what mine looks like in the S500 as it came from the factory. It has a Motorola V60 blue tooth puck that sits in the empty slot. Has worked with every phone I have owned via the command and/or voice commands.
Attached Thumbnails Where do I install B67875855 Blue Tooth Adapter on 2004 S430?-silver-shadow-twenty-six-2-.jpg
Old Aug 4, 2016 | 08:34 PM
hififan's Avatar
I do not have the cradle. I plugged the "puck" into the connector below the shelf floor. It seems that I may need version coding. Thought I am still researching. The puck and my cell phone have found one another; Command says no telephone. Thank you for the picture and the response. John
Old Aug 5, 2016 | 12:15 AM
tusabes's Avatar
Mercedes
You bought thepuck with tail" to connect without using the oem cradle
Old Aug 5, 2016 | 10:28 AM
hififan's Avatar
Yes. The part number I referenced is the blue tooth "Puck." Thank you
