Aux air pump location on S 55 Kompressor ?
Where is the Auxiliary air pump {smog pump} on the M113k engine located ? It's not in the front of the motor, like it is on the S 500. The check valve inlets are connected to fittings cast into the supercharger housing. I don't see any plumbing or pump on the firewall side of the kompressor. Anyone know ?
2005 S 55 AMG
2005 S 55 AMG
"Right front fender liner area" As viewed from sitting in the driver seat {I assume} or as viewed from standing in front of the car ? I'm located in the USA , BTW. Thank you for taking the time to reply, AMG Seahawker.
Yes from driver seat. If you take the front passenger fender liner out you will see it. Towards the front of the vehicle
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
2005 S 55 AMG
2005 S 55 AMG
Moved over to the dark side from Bimmerboard I see! I was there too at one time as bob91750.
Anyway, I'm attaching the WIS instructions for removing the pump which is accessed from the bottom.
Good luck,
Bob
(Be sure to check out Benzworld forum as well.)
