Buying older W220
Are there pitfalls to buying an older S Class, I've seen a few post advising that pre 2003 models should be avoided, why is this? I'm looking at a late 2001 S280. It's been on sale for a while and has been reduced to £999. It's done 71K, everything seems fine except for a few surface rust spots which I can easily fix.
thanks.
They are great cars , eArly cars did have more rust and suspension problems though
The 2001 nav system uses CDs. No idea about the UK, but it takes nine CDs to cover the entire USA, and you must buy at least the one CD that covers your area. The CDs aren't cheap - and they are not (at least in the USA) anywhere near up to date. The user interface is pretty bad. Having an old system that is fully integrated with the rest of the Command system is nice in a way, but it is, and will continue to be, obsolete.
The antenna and wiring may or may not be installed - apparently this varied by market. If not, adding it as original will require extensive disassembly.
The trunk-mounted CD player will be much the same. It will play only music CDs - no mp3 or DVD music. If the wiring is not there and complete, installation will be difficult.
It will sounds as if it will be a nice car - but I doubt that trying to make it a fully-equipped version would be worthwhile.
Sorry...
Nick
Rebuilt struts are not that big of a cost anymore but if the car is only £999 yes they can cost more then the car itself if three or four need replacement
You are looking at a £999 car . All cars in such low price range may need costly repair in the future , it's a gamble you have to take when buying such an old car without warranty , the best thing you can do is see if the seller will let you take it to an independent mechanic for a prepurchase inspection . I realize you might not want to spend £150 on a car inspection but it's usually well worth it.
Spend some time reading this before you need it.
https://w220.ee/Airmatic
