'05 S55 - ABC - Ride Height Button randomly lights-up after start
Old 03-08-2017, 04:45 PM
homejones's Avatar
Ss
Hello,
I think I have an electrical gremlin in my 2005 S55 (or an ABC issue). Every few starts, the car's ride height button appears to be activated on the first level (the first light on the button).
To be clear, I always drive with ABC Sport at the standard height level so not sure what is causing the issue. I never drive my car with the vehicle height raised so for one reason or another, the car will sometimes start with the first light on the Ride Height Button illuminated and the ABC Sport light off.
No ABC errors on the dash. Any insights on what is going on...?
Old 03-08-2017, 05:27 PM
compaddict's Avatar
2016 S63, 2013 SL63
Check your battery voltage. Weird things happen when low or failing battery.
I don't think I have seen that problem though.
Old 03-08-2017, 06:10 PM
homejones's Avatar
Ss
I thought it may have been electrical, but I just changed the Alternator and still having the issue.
Old 03-08-2017, 06:41 PM
compaddict's Avatar
2016 S63, 2013 SL63
How old is the battery and what cold voltage?
My battery was okay but I knew it was a little down. When I flashed the ECU it showed it's age and I had to buy a new one to complete the flash.
After that my gremlins went away.
YMMV
Vince
Old 03-09-2017, 11:34 AM
homejones's Avatar
Ss
Looks like a battery was installed in 2016 judging from the date written on the battery in chalk (must have been an auction lot or the lot I bought it from). It was also charged by the indy shop after I replaced the alternator. Problems still continued after the alternator change and the battery charge last week.
When I hookup my scanner to the car, I also see some random CAN faults that I can't explain.
Will check voltages tomorrow morning and report back.
Old 03-10-2017, 09:03 AM
TNJohn's Avatar
2006 S500, 2013 Jaguar XJL Portfolio
+1. Have had this issue with a few makes in the past. My Volvos were the worst for this.
Old 03-10-2017, 10:05 AM
homejones's Avatar
Ss
Cold voltage: 11.6-11.7
Post start voltage: 13.9-14.1
Old 03-10-2017, 10:30 AM
compaddict's Avatar
2016 S63, 2013 SL63
I will check mine this am. Seems low.
Old 03-10-2017, 11:08 AM
wallyp's Avatar
2003 S500 2007 GL450
Values are low. A fully charged battery is around 12.5 - 12.6 volts, running voltage usually around 14.4 - 14.6 volts.
A weak battery can cause strange problems on a W220...
Old 03-10-2017, 11:09 AM
homejones's Avatar
Ss
Okay - good info.
Do you guys think it's the voltage regulator or the battery? Not sure if the voltage regulator was also changed when I got a new alternator last week.
Old 03-10-2017, 11:28 AM
wallyp's Avatar
The voltage regulator is normally part of the alternator, comes with it. Probably the battery.
Old 03-10-2017, 01:23 PM
compaddict's Avatar
2016 S63, 2013 SL63
12.32 cold.
Old 03-10-2017, 02:26 PM
tusabes's Avatar
Mercedes
11.6 cold indicates a weak battery
Old 03-10-2017, 04:25 PM
homejones's Avatar
Ss
Will check at the battery terminals tomorrow morning. Checked from the hidden menu in the IC when I posted those values earlier.
Would a charge fix it or do I need a new battery?
Old 03-10-2017, 05:21 PM
tusabes's Avatar
Mercedes
Unless the car has been sitting Undriven , a charge probably won't help
Check the date code on the battery , if older than 3-4 years old you'll probably need a new one
Old 03-11-2017, 11:48 AM
homejones's Avatar
Ss
See photos below...
Taken at the battery this morning. Taken from the IC when car is in ACC position.
Battery label
Old 03-11-2017, 08:32 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
A reasonably charged battery should show at least 12.5 v.
Quick Reply: '05 S55 - ABC - Ride Height Button randomly lights-up after start
