2003 S430 not starting
the key will.not turn with insufficient voltages
You also want to check is the prefuse under the passenger floor and apply power there
you can't just put a used eis in, what you'll want to do is buy a matched set of the key , eis , ecu and shifter taken from the same donor car . Matched sets cost about $350 on eBay . You must swap all 4 parts or else it will not work
Edit: came across this during a search. Might help you out.
http://www.benzworld.org/forums/r230...er-dashes.html
You would have to buy a new eis from the dealer and have it programmed by the dealer (and they will require you to tow the car in , as this is part of the anti theft system - they will not sell just the part to you , they need to verify ownership and install it ) .
buying just an eis from a dealer will cost far more than buying the 4 matched used parts - eis , key , shifter and ecu from a donor car . No programming is needed if you buy the matched set from a donor car
but first please check the fuse I showed you - it may be the simple problem and you might not need the 4 parts .
Also if you like to do lots of reading , you might want to read through the first ten pages of this post -
http://www.benzworld.org/forums/w220-s-class/2693609-s500-resurrection-daves-thread.html
this was a mechanic who ran various tests trying to narrow down the issue to a single part , but in the end buying the 4 matched parts is what solved his problem
different part numbers don't necessarily mean it won't work - sometimes the different part numbers will also work fine too . But sometimes the different part numbers will have some issues, and you just need to try them to see if it works , with the understanding you may need to resell or return them if they don't work in your car
I don't think there's any way to tell for sure when trying to swap parts with different part numbers
