Best oil weight s600
However, never use a -30W oil with the V12TT. The high temperature shear strength is too low. Always use a -40W.
Nick
https://bevo.mercedes-benz.com/bevolisten/229.3_en.html
There are other things apart from shear stability and viscosity that manufacturers consider when approving a specific oil for a particular vehicle. Some formulations come from a specific base that the manufacturer feels would best meet engine performance requirements. Others have additives, etc.
The best thing to do if unsure about oil performance is to perform an analysis. I've used Blackstone labs in the past. You take a used sample of oil and send it to them. In turn the provide you with an analysis the covers oil condition, the amount and type of metals and chemicals found in suspension, etc. This gives you an overall idea as to how engine wear is progressing and if the oil is able to provide sufficient wear protection.
http://www.blackstone-labs.com/
Here's a sample of a UOA from Blackstone:
