My car/story and it's problems---CURRENT ISSUE---Alignment!!!???
I have a 2005 S430 4matic which I use as my daily driver and I drive a lot for work.
I purchased this car in December and I replaced the engine with one from a 2001 E430 Sport which I owned. My wife was in a minor accident but it caused enough damage to the rear/side of the car to be a total loss to the insurance company. I bought the car back from them and used the very strong engine for this beauty I have now.
This car came fairly cheap because of the issues it had. Some of the issues, aside from the engine, were front passenger sided air strut, collapsed rear suspension, catalytic converters on the passenger side, tires and loose steering rack. The rack had what translated into about a 2 cm dead spot. A spot where I could turn the steering wheel either direction and it wouldn't do anything to the direction of the wheels. This would happen while driving straight or while in corners. I replaced the steering rack and at the same time I replaced the inner and outer tie rods on both sides. I figured if I'm going to get new tires and an alignment, I might as well use new parts for this whole process.
Parts swapped out, alignment done and new tires mounted, balanced and installed. Drives tight and straight. I'm happy.
Two months after the steering fix, my wife and I take the car for a cross country trip to view the Great American Eclipse. From Massachusetts to Wyoming and back. The only problem we had during the trip was the front catalytic converter broke apart inside and clogged the rear converter creating severe back pressure causing misfires on the whole right bank of cylinders. After thinking about my options while 2000 miles from home.....finding a shop to fix this for free (I have no extra money) was not an option.
I found a hardware store and bought a couple drill bits that would work with my battery powered impact driver. I figured the rear converter was junk so I drilled enough holes in the front of the converter to relieve some pressure while running so I wouldn't get the misfires. This worked well with the exception of the hills in Pennsylvania. Codes would fly as soon as you get your foot in it to make it up the long and steep hills. Not a huge deal....just would pull over, clear the codes and then get back on the highway with a little less effort in the throttle department.Made it home Saturday evening and started to work on the exhaust on Sunday. While jacking the car up I noticed the inside of both front tires are smooth. WTF??!! Brand new tires...now junk.
What would wear the tires like this...toe alignment is all I can think of. But why would the toe alignment be off? I just replaced the rack and inner and outer tie rods just before the alignment. What else could throw off the alignment? I don't see anything that's loose. Upper and lower ball joints seem good.
The only 'odd' feeling I've had with the steering was an occasional 'slipping on a small patch of ice' sensation when turning a bit aggressively in a corner. It was very slight....and I only thought it was just a weak sidewall because they're nothing special for tires.
What would cause this sensation? Possible ball joint going bad? would this also cause the alignment issue?
Any thoughts? Follow up Questions? I'm open to anything.
Thanks in advance.
PS. The "Total Solar Eclipse" was absolutely amazing! I would do this trip again in a heartbeat to see it.
On the catalytic convertor, I sense you can pick up a assembly from a parts car. The issue I have had with a S430 in the north has been the exhaust bolts and flanges rusted and melted together. What would be a 60 minute exhaust system replacement for a southern W220 took me excessive time and retrofitting because of the exhaust system flange, bolt, and nut corrosion.
I will be monitoring your thread, keep us up on what you are finding....
car has 220,000 miles and suspension is original . I just buy from a reputable tire shop with a good mileage warranty
the wear is even across the tread so it's baffling
It's very frustrating. I work on my cars to save money....and this just feels like I'm pissing money away.
I'm attaching pictures of the tires.
I'm a bit confused? Do you just keep throwing new tires at your problem? Or, have you had your reputable tire shop fix the issue? If so, what was the issue?
I went to change the right side....and this is what I saw!!!!!
I'm thinking the ride height of the car might have something to do with it.
What does anyone know about having a 'low' ride height and wearing out the inside edge of ALL 4 TIRES on a 4Matic w220?????
I'm going to start a new post about the ride height potential.... Here
https://mbworld.org/forums/s-class-w...ml#post7258652
The front tires were worn because even though I had replaced the inner tie rods and the tie rod ends during a steering rack swap, I found one of the inner tie rods prematurely had some in/out play. This wrecked the front tires.
The rear tires were worn/destroyed because at some point during the trip the upper control arm's rubber bushing essentially fell apart. This threw the camber WAY OFF! And with the added weight of our traveling gear, the lower ride height the car is typically at and the even lower ride height while traveling at highway speeds, stressed the tires beyond their point of reliability.
As far as the catalytic converter....I bought a front pipe off ebay and installed it.
2 things I should have been aware of when searching on eBay for this pipe....
2. check the compatibility of the O2 sensors
3. change the O2 sensors if necessary before installing the pipe
Fortunately, the pipe fit. It was fairly close to the front drive shaft but not touching. The pipe came from a 2000 S500 and the O2 sensors are definitely different than what I needed in my 2005 S430 4-Matic. Threw a couple codes pointing directly to the O2 sensors. I was able to remove my sensors and reuse them.
I hope this helps with anyone's situation with similar wear on their tires. I'm sure there are more issues that can cause the same wear, but this is what I found on my car.
Good Luck
Vince
