Oil leak engine front
Old Sep 16, 2017 | 02:00 AM
Samorai981's Avatar
S320 1999 w220
Hi
i just bought S320 1999
found that some oil is comming out if the front of the engine.
looks like the screw shown in the photo have some kind of a seal or thread that is worn.
please help as i don't want the mechanic to open the wrong side and start replacing stuff.
Thank you
Down the engine front
Old Sep 16, 2017 | 03:06 PM
wallyp's Avatar
2003 S500 2007 GL450
It appears that the leak is from the front crankshaft seal. Repair requires a couple of special tools, so an independent shop that works on Mercedes Benz vehicles is probably the best approach.
Old Sep 16, 2017 | 04:32 PM
tusabes's Avatar
Mercedes
If it's not a severe leak you can just leave it alone
all old engines leak . Chasing down one leak after another is an exercise in futility . Another leak will just spring up in a different area on a car this age
Old Sep 17, 2017 | 02:52 PM
Samorai981's Avatar
S320 1999 w220
the oil is comming from areound the (screw) in the middle of the photo.and now i can see oil under the car in addition to the smell of burning oil.
someone tried to seal arround the (screw) with selecon as i see in the photo.
any ideas what is this screw?
thanks
Old Sep 18, 2017 | 04:30 PM
engindin's Avatar
2002 S320L
Hi Samorai,
i hope you know that your timing cover is removed recently, no one can clean your upper cover like that in the picture.
i think leak is coming above these screws, isnt it? As i remeber there should be one more m8 under tensioner pulley. Better remove tensioner, belt and inspect under. I can see also your bottom cover full of oil residue. i think timing cover job was not done well.
i couldnt see any silicon there, i dont think someone tried to seal the hot engine cover with silicon?
Is it leaking when engine off or only running?
Old Sep 18, 2017 | 05:04 PM
engindin's Avatar
2002 S320L
Additionally, check the bolts with arrow, they should be sealed by proper selant, if it is silicon i think you need to renew all
Old Sep 19, 2017 | 01:15 AM
Samorai981's Avatar
S320 1999 w220
Originally Posted by engindin
Hi Samorai,
tbanks engindin. Didn't notice that.
The leak is actually coming from arround the screw like down under the tensioner. Not from behind. I uploaded Screw like way below the tensioner
Nithing coming down from behind tensioner
Oil is splashed from the screw below to the tensioner
Some more photos might give a clear idea.
Old Sep 19, 2017 | 09:28 PM
S430AMG's Avatar
2006 S430 AMG
When it comes to leaks, first thing I would is figure out how bad it is. If it's slow, I wouldn't take any action (but still would try to identify it/if possible).
I''ve had cars with minor leaks for YEARS (10 years on my MPV), it does 0 harm and I don't even have to refill the oil on regular basis.
Old Sep 20, 2017 | 02:02 AM
Samorai981's Avatar
S320 1999 w220
when the engine is on, one drop per second. Now i can see oil spot under the car.
Old Sep 20, 2017 | 07:23 AM
wallyp's Avatar
One approach would be to clean the area and determine exactly where the leak is, and then take care of the leak.
A couple of possible approaches:
Scrape as much crud off as possible, then buy three or four spray cans of "brake & parts cleaner", some good rubber gloves and several rolls of paper towels. Take the usual precautions - outdoors, newspapers on the ground, eye protection, etc. Spray the top of the area, wipe off crud, repeat.
Buy some cans of "heavy-duty engine degreaser". Scrape as much crud off as possible, same precautions, spray degreaser over the area, use garden hose to clean the area.
After the area is clean, find the leak - sometimes easier said than done. Clean oil is hard to see. Use a very good flashlight or drop-light to help.
If the leak is a bolt, remove that bolt, clean the bolt and hole, apply clear silicone sealer, replace the bolt and let the sealer cure. Check again for leaks.
Old Sep 20, 2017 | 08:27 AM
S430AMG's Avatar
2006 S430 AMG
Ok, that's a bad leak.
Spray some brake fluid in there and clean it up good, see if you can spot where it's coming from.
Another way to spot it is to again clean it really good and put some dye in oil and shine a black light on it to see where it's coming from.
Your mechanic should've done this.....I would find another. But first, I would do my best to isolate the leak myself.
Old Sep 20, 2017 | 06:19 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
Clean it well, then spray some " Bon Ami" cleaner on it, and let it dry completely.
Restart and watch immediately, you'll see the source of the leak.
Good luck!
