My S600 headach
Old Sep 17, 2018 | 10:14 PM
Richierich97's Avatar
2001 Mercedes-Benz S600V
My S600 headach
Good day
My name is Richard and I am the proud owner of my headach 2001 Mercedes-Benz S600.
I bought the car about 3 years ago and been working on it ever since. I do not plan on selling the vehicle nor daily drive it. It's more of a personal project/challenge.
which brings me to my point, I bit off more than I can chew.
the cars biggest problems are cooling and misfire which I can't seem to figure out.
I bought the vehicle with 6× miss fire on left side of the engine. A hole in the radiator. And fan assembly not kicking in.
Since then. I have replaced the coil pack with a tested/warranty used one that has worked. Replaced the radiator with a OEM used radiator. Replaced the temp sensor and thermostat assembly with OEM new from Mercedes, And also replaced the water pump also OEM from Mercedes. With all new fresh coolant.
At first after starting it up it was running perfect. No codes firing on all 12 and nothing to complain. Engine didn't over heat while idling or test driving but I already noticed that the fan never kicked in. After about 10min idling after the test drive it starts to shake and miss fire. Read all codes and it was miss firing on 3 cylinders. Believe it was 1 5 8. At the same time I got a coolant warning light and the engine started over heating.
Following day. Kept testing the car. Started missing on 4 cylinders and doesn't cool at all any more.
now is missing on 6 cylinders(cyl, 1.2.4.11.9.12) and also doesn't cool anymore..
current engine codes are following
p2073,p2050,p2051,p2055,p2056,p2058,p2059,p205A,p2 043,p2044.
Old Sep 17, 2018 | 10:33 PM
tusabes's Avatar
Mercedes
Originally Posted by Richierich97
Good day
change all the spark plugs*
change all the red coil insulators*
rent a voltage transformer and coil from v12icpack.com and use them to narrow your issue*
Old Sep 17, 2018 | 11:14 PM
I have gotten in touch with v12icpack and will def use their services. I have inspected all the red insulators for any cracks of signs of wear. Only thing I haven't gotten to yet was to pull the spark plugs. I had them out about a year ago and all tested good. Cleaned them up and checked measurement and put them back in. Will for sure pull them again and consider changing them all.
Old Sep 18, 2018 | 01:30 AM
ItalianJoe1's Avatar
2003 CL 600
Fan controller is most likely bad if the fan won't come on. Happens a bit on those setups.
Old Sep 18, 2018 | 09:00 AM
does the fan control module need to be programmed to the car? Or is it just plug in? Also where is it located on the vehicle?
Old Sep 18, 2018 | 10:00 AM
Welwynnick's Avatar
2006 S600
Fan controller is hardwired to the fan motor and very difficult to separate. You really need to replace the whole fan. It has to be a 850W fan. I bought one from an S320CDI. The motor is integrated with the fan. There is no belt drive on the S600TT. There's no programming needed.
What spark plug gaps do you have? It should be 0.7mm / 0.028".
Nick
Old Sep 18, 2018 | 10:18 AM
Nick
is there any way to check the current fan assembly that is in my vehicle? I noticed that there isn't any coolant pressure building up in the hoses but once it overheats to far the coolant gets pressed out through the overflow hose/reservoirs.
and I forgot what the spark plug gap was but I will pull the coil packs and spark plugs today. Will let u know about any finds or the gap.
Old Sep 18, 2018 | 02:30 PM
tusabes's Avatar
Mercedes
You might need a new thermostat too
Old Sep 18, 2018 | 02:45 PM
2003 CL 600
Check the cap on the reservoir if there's no pressure building up. The seals go bad on them.
Old Sep 18, 2018 | 08:39 PM
wallyp's Avatar
2003 S500 2007 GL450
"I have inspected all the red insulators for any cracks of signs of wear. "
I think that Mercedes says to replace these every time that the ignition units are removed. If so, it sounds as if Mercedes considers these to be critical parts.
