Gear stuck in Parking
I have 2005 Mercedes S500. ONLY in winter when it is cold and if the car stays out in parking lot for 4 to 5 days, car starts with no issue but I can't change gear form Parking to reverse/drive position. Any help would be much appreciated
Nitin
The brake pedal brake light switch is not functioning in very cold weather. Check the brake lights to see if they are functioning when the lever doesn't release.
There is excessive drag in the solenoid and/or the plastic lever in very low temperatures, preventing the lever from moving. Try jiggling the shift lever while pressing the brake pedal.
The plastic lever is cracked, and doesn't move far enough to release the shift lever. You can buy a kit, consisting of two or three different sizes of metal replacements for the plastic lever. Installation is feasible for a reasonably experienced DIY owner.
. Is there any permanent solution for this issue??Thanks for your advice.
Nitin
I am currently dealing with a problem which won’t let me release the car from park when cold. On the warmer days (+1 celcius), it moves to the other positions just fine, but when it’s below 0 celsius it won’t budge.
When first trying to move the shifter to the right before going downwards, it’s kinda sticky like it’s frozen. I can’t seem to find any post describing it like me.
If I jack up the car and put a heater directly under the shifter lever and leave it for about 30-60min, it will release from park.
Im thinking maybe there is a water drop or something inside the shifter and have thought of spraying a little wd40 or crc inside, but I don’t want to do that since I have read that the shifter is super sensitive to any form of liquid and will break.
I can’t understand which broken plastic lever you guys are talking about, could someone please elaborate? Maybe this is the problem i’m having
Thank you.
I have thought about the solenoid, but I do hear a click from the shifter when I press the brake. If i have understood correctly, this means the solenoid is fine
https://www.benzworld.org/threads/sh.../#post-3577185
https://www.benzworld.org/threads/sh.../#post-5696819
https://www.benzworld.org/threads/sh...#post-11438137
https://www.benzworld.org/threads/sh...#post-17261082
There are over twenty pages of posts on this problem.
