2000 s430 Suspension question
It might be a common problem with the 220 but it certainly isn't normal. This problem never occurs on my S class. There could be a leak in the air suspension. Hopefully your car is still under warrantee. I'd give it to Mercedes and let them resolve the problem. Good luck.
thanks man.
the rising is normal after you open the door(s) and/or start the car. It'll lower itself after you have shut all the doors and engine off after you get out.
if its not normal...oy vey.
i assumed the hissing noise was normal because the suspension was releasing the air to lower the car? the lowering and rising of the car when locked/unlocked is normal.
Dealer said it was not normal. Since they replaced the mentioned parts, it no longer makes the noise or goes up and down, only when I press the height button.
I had mine suspension changed on driver side cos it sometimes goes down completely and the body is sitting right on the tire. After changing the suspension with Arnot suspension, I noticed it doesn't do the hissing noise and rising anymore and the car balanced up but if I pressed the rise button on the dash it will rise. So back to my question was it normal for the hissing noise and rise b4 I changed my suspension or was it cos it was leaking air that was the cause of the hissing noise and rising?.
I will greatly appreciate any information or ideas on this issue.
Thank you all.
Any suggestions will great appreciated pls.
Thanks you all.
