Only 12 mpg
Old Mar 8, 2019 | 01:44 AM
Will Hunt's Avatar
2008 s550
Unhappy Only 12 mpg
I have a 2001 s430 with 190k miles I have replaced the air filters and spark plugs and cleaned the maf. I mostly drive just to work in town ( 5 mile round trip) and barely go past 3k rpm but I only get 12 mpg what else could be wrong?
Old Mar 8, 2019 | 07:39 AM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
Bad MAF
Low Compression
Plugged cats
Worn Cam
Slipping transmission
Dragging brake
Bad alignment
Bent or worn suspension component
Cleaning the MAF rarely works well. But if the engine runs OK, it might have worked.
I would start with a general inspection on everything. How are the tires? Is one brake really hot when you're done driving? How's the tire wear?
If all that's OK, check compression, and if that's OK, change the MAF...
Old Mar 13, 2019 | 12:29 AM
Will Hunt's Avatar
2008 s550
Yesterday I got a p0110 code and the engine doesn't have a smooth idle. Could it be the maf?
Old Mar 13, 2019 | 07:55 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
google the mb codes and you will learn!
Old Mar 13, 2019 | 10:34 PM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
P0110 code will be often preceded by the Check Engine Light coming on the vehicle dashboard display. The vehicle will most often not run well, idle poorly, accelerate erratically, run rich and backfire because the IAT sensor and throttle position sensor are not electrically synchronized together.
Most likely, this could be the cause of your poor mpg.
Old Mar 13, 2019 | 11:05 PM
Will Hunt's Avatar
2008 s550
Is there a way to synchronize the IAT and throttle position sensor?
Old Mar 14, 2019 | 05:07 PM
rustybear3's Avatar
There are voltage measurements involving both. Depending on the severity of the condition, the diagnosis and repair for error code P0110 can be meticulous, if not difficult, and would definitely require advanced tools and of course, skills. If I were you, I wouldn't hesitate to take your vehicle to your dealer or to a qualified mechanic.
Old Mar 16, 2019 | 11:23 AM
RollTideW163's Avatar
2014 GL450, 2006 S500, 2003 ML350, 1996 C280 (Prev 1995 C220, 2002 CLK320, 1980 300SD Turbo)
Have a look here https://www.obd-codes.com/p0110
