Headlight browned after taking bulb out and leaving it 5 minutes
Old Oct 5, 2019 | 08:53 PM
Two Scoops's Avatar
2003 S430 4matic
Question Headlight browned after taking bulb out and leaving it 5 minutes
So I was changing one of my headlight bulbs: drove to the parts store, twisted the block off from behind the bulb to take the bulb out, left the block off and brought the bulb inside to match, came out 5 minutes later to put the new one in and my headlight looked like the picture. Any ideas?
Old Oct 6, 2019 | 12:07 PM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Maybe you didn't notice before that the polycarbonate lens turned brownish already???? The color change has nothing to do with the bulb change. The headlight is not a sealed type, it make no difference if the bulb is out or not. My guess is that the UV light has worn the polycarbonate surface over the years. There is polish on the market to clean the outer surface of the lenses. I have never done it, but you'll find information on YouTube
Old Oct 6, 2019 | 04:38 PM
Two Scoops's Avatar
2003 S430 4matic
It's highly unlikely that it had already turned brown and I didn't notice, as it affects the headlight's colour when it's turned on. I will check again to ensure it's not an outer lens discolouration, although I'm quite sure I checked at the time this happened. Will report back if I discover anything.
Old Oct 7, 2019 | 01:14 AM
Fried Chicken's Avatar
2005 S500 Designo
Only explanation would be fresh air getting into the headlights and somehow reacting with them to turn it brown.
Unfortunately that means you'll have to either clean the lens, or replace it entirely. Interesting phenomenon.
Old Oct 7, 2019 | 05:15 AM
As I said before, the headlight is not sealed, and normal air always has access to the inner assembly. There is no "quick" (5 min) chemical reaction, by removing the bulb. You can check if the brown stuff is on the inner surface of the lens, by try to wipe it off through the bulb hole, wihba "long Q-Tip"
Old Oct 7, 2019 | 02:58 PM
tusabes's Avatar
Mercedes
You didn’t notice it . Why were you changing the bulb ? Because it burned out right ? When bulbs fail they can cAuse this when it burned out
so it’s not like it was always brown and you didn’t see it , it just turned brown when the old bulb burned out
Old Oct 7, 2019 | 03:31 PM
How should a burnt bulb color the inside of the lens??? Did it explode and set the housing on fire? If the bulb just stopped working it would never discolor anything.
Old Oct 7, 2019 | 07:15 PM
tusabes's Avatar
Mercedes
Many times they emit smoke when they finally burn out which would discolor the lens
Old Oct 8, 2019 | 01:49 AM
If that's the case, then it shall be possible to just spray the inner lens surface with brake cleaner, to remove the "smoke traces"
Old Feb 5, 2020 | 06:33 PM
Two Scoops's Avatar
2003 S430 4matic
**SOLVED**
Thanks for the input fellas, turns out it was on the outside after all; I somehow didn't notice it before the bulb burned out... or when I took the bulb out haha. Just wanted to update to avoid other people thinking they might have this problem. Thanks again!
Old Feb 6, 2020 | 09:52 AM
wallyp's Avatar
2003 S500 2007 GL450
Thanks for the update!
