DEPO Headlight Upgrade
I saw these DEPO halogen headlights:
https://www.ebay.com/itm/DEPO-Faceli...ry!80920!US!-1
I think they can be converted to HID headlights.
I was thinking of installing E46 projectors or Acura TL 3G projectors and ballasts in them.
Has anyone converted these DEPO halogens before? Are any other parts needed?
it’s Much better to use a factory built solution. You have to order it for 2000-2002 model with oem xenon and leveling
https://www.uniquestyleracings.com/s...bzw22000dpprom
The results, as I like to say, "burn vampires at night". :-)
@tusabes, he may be in the same position that I was in when I did my conversions and bulb/projector tests. He's in exactly the same situation that the 2003 S430 was in (factory halogens), and almost exactly the same situation as the project 2000 S500 (factory xenons). In both cases, the DEPO's are a direct plug-n-play replacement, plus they have that auto-leveling motor that the Genuine-MB/OEM ones have, for a lot less money than OEM.
He would do badly to buy the DEPO bi-xenons because the pinout is slightly different. Our '03 S600 TT is a factory bi-xenon car, and the ground wire is on the second plug instead of the first. Why M-B did that, I don't know, but they did.
They are supposed to be made in an ISO certified factory:
https://www.ebay.com/itm/2000-2005-M...nd!80920!US!-1
You are aware, BTW, that those are halogen assemblies, right?
One other guy over on the other forum seems to have had good results with these cheap Spec-D headlight assemblies. Maybe you'll get lucky like he did. But there's a reason I stuck with DEPO for my cars.
I'd go with these instead.
Whichever way you go, please do use proper HID components. The proper components for a W220 conversion are as follows.
1.) Morimoto E46-R bi-xenon projectors (available from The Retrofit Source)
2.) Hella Gen 3 ballasts (available quite reasonably from www.hidprojectors.com)
3.) Good OEM D2S bulbs, namely Jahn, Osram, or Philips--I mostly use Osram
4.) Some spare copper wiring--you'll need it, trust me (local hardware store)
5.) Heatshring tubing (also local hardware store)
5.) Butyl sealant for headlamp assemblies (also available from The Retrofit Source)
That will get your headlight assemblies as good as the Genuine-MB ones.
