Need Some Help/Advice On Replacing Front Lower Control Arms and Axles
I am not looking to break the bank, but want to buy parts that are reliable.
I need to replace to front lower control arms and the front axles (axle boots were torn - so I figure I would replace the axles while doing the control arms at the same time).
Just looking for some advice or thoughts/opinions on what to buy here?
Lower Control Arm (complete control - includes bushings)220-330-73-07 $458.85 (left) - Genuine Mercedes Parts
220-330-74-07 $448.50 (right) - Genuine Mercedes Parts
Additional Options for Lower Control Arm:
Vaico Control Arm & Ball Joint Assembly; Front Left Lower - $222.99
SKU: 1440100-V301811
P/N: V301811
Vaico Control Arm & Ball Joint Assembly; Front Right Lower $231.99
P/N: V301812
Axle Assembly
220-330-02-00 $1,128.60 (left) 220-330-00-01 (updated part number) - inner and outer boots come with purchase. Genuine Mercedes Parts
220-330-01-01 $855.00 (right) 220-330-54-20 (updated part number) - inner and outer boots come with purchase. Genuine Mercedes Parts
Additional Options for Axle Assembly:
DSS Axle Shaft Assembly - $122.99
P/N: 2D-2203300001
DSS Axle Shaft Assembly; Front Right - $122.99
P/N: 2D-2203300101
GKN Loebro Axle Shaft Assembly - $455.99
P/N: GK-2203300001
P/N: GK-2203300101
Also - if anyone has any tips/advice on doing the actual replacement.
Thanks in advance
There is a pretty hefty difference in price, so I just wanted to get some opinions ahead of time. The stealer can replace these (quotes) for about $8,000 (parts included)
I found a decent mechanic who can do it for pretty cheap if I order the parts.
Thanks again.
Thanks again.
you can try the cheap aftermarket for the axles
There is a pretty big price differential between the DSS brand axle shaft assembly ($122.99 each side) and the GKN Loebro Brand ($455.00 each side).
I am not familiar with either and have no experience with using these types of parts on the Mercedes. The previous owner only used the dealer and used Mercedes Genuine Parts for all of those.
Thanks again.
Thanks again.
I was checking out the thread on the torn axle boots. Do you think I could just replace the lower control arms and (as suggested in that thread) potentially just remove and clean the parts from the axle and replace the boots instead?
At what point does it make sense to just replace the axles altogether? And would it be better to keep the genuine mercedes axles I already have and instead just replace the axle boots?
Otherwise - I could replace them (and the DSS brand is quite inexpensive at $122.99 each). That said - I wonder if there is a reason WHY they are so cheap (i.e. unreliable).
Thanks again. Very helpful.
if you are relying on the report from the dealer I would get a second opinion and have another trusted mechanic carefully look to see if the parts indeed need replacing . I’ve seen dealers recommend replacement of parts having any slight sign of wear even if they may last 50,000 more miles . A Mercedes dealer is trained to recommend parts to bring your car to “new car” status . The fact is these are old cars and having parts with wear is fine . Only replace Control arms and the boots if substantial rubber cracks are visible , not just the beginning hairline markings that may be fine for 50,000 miles
I also had a torn inner cv boot from a bad engine mount. Cleaned up the joint and just replaced the boot (kit was $30 from eeuro)
