F62 20 amp fuse keeps blowing
most likely Your trunk lock has a short or vaccum leak causing the pump to blow the fuse
You could try unplugging the PSE pump and see if the fuse still blows. The pump is located in a sound-proof housing behind the trunk lining in the forward left corner of the trunk.
chuck
