Silicone in reservoir
somebody PLEASE say it ain’t so!!!
they said what they found is that the heater control value is sticking and that is why I am not getting heat.
They said they don't know why its sticking but they recommend that I replace it and flush the system and add a VPS additive to the system.
There is a "duovalve", which controls the flow of coolant to the left and right heat exchangers (heater cores), and also pumps coolant for the "residual heat" function. The duovalve is located between the two rear bulkheads in the engine compartment, under the wiper system. It is pretty common for the duovalve to get stuck. Often, you can solve duovalve problems by removing, cleaning and replacing the duovalve.
This might help.
https://www.benzworld.org/threads/so.../#post-5094753
