2001 S600 Crank Position Sensor
Old Jun 3, 2022 | 04:26 PM
I drive a Ford's Avatar
2008 Ford Crown Victoria
Does anyone know if it is necessary to remove the intake manifold to replace the crankshaft position sensor on a 2001 S600 V-12?
The WIS software says the intake manifold must be removed, but I have seen threads online saying it doesn't have to come off.
Anyone familiar with this job on this model? Thanks!
Old Jun 3, 2022 | 06:30 PM
Fried Chicken's Avatar
2005 S500 Designo
I remember when deciding not to do this job when I was contemplating it.
It would be easier to do with the transmission removed
Old Jun 3, 2022 | 08:12 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
The cps on the S600/M137 can be accessed by removing just the inlet cover.
You need a long 1/4 " extension and a universal with the socket to reach it.
Since you don't want to drop the bolt, you need to be a bit inventive (magnet or sticky stuff).
It's on top of the the engine just above the flywheel,
Do you know it is bad?
Good luck!
Old Jun 4, 2022 | 07:52 PM
Good luck!
Thank you! Yes, I know it is bad because I got the error code P0335 for Crank Position Sensor fault on bank A.
Also, the car will not start again until it cools down for a couple hours. I believe that's a sign of a bad CPS also.
Old Jun 4, 2022 | 07:56 PM
It's becoming clear to me that when they designed this car, if there were 10 ways to do something, they never failed to pick the method that would inflict the greatest amount of difficulty, and frustration on anyone attempting to repair it!
They crammed a V-12 in there I guess that's all that mattered at the time.
Old Jun 7, 2022 | 03:31 AM
2005 S500 Designo
Quit whining and figure it out. It's a terrible job.
Old Oct 22, 2022 | 01:33 PM
kraut56,
I searched the WIS and couldn't find the part called "inlet cover" or anything with a name like that.
Are you referring to the part that is directly behind the throttle body that splits the intake air into a Y with one branch going to the left cylinders, and the other to the right side? I'm sorry if this is a stupid question, but I just want to be sure I don't take off the wrong part. Thanks.
Old Oct 22, 2022 | 04:29 PM
kraut56's Avatar
No, it is the engine cover that also is part of the airfilters; easy to remove.
Put the hood up into the full maintenance position, remove the engine (air filter) cover, and then lean all the way over the back of the engine.
down there, just forward of the bell housing joint, is the crank pos sensor.
Old Oct 23, 2022 | 09:00 PM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
Even better than magnets in sockets - I just discovered these -
https://kokenusa.com/products/1-4-sq...-rail-set-6-pc
I cannot tell you how great they are! Much more secure than a magnet insert, or my old standby, the piece of blue masking tape.
Old Oct 23, 2022 | 10:59 PM
wallyp's Avatar
2003 S500 2007 GL450
That might be worth trying. Two steel *****, a wide rubber band, the right-size drill bit, and a spare 10mm socket...
Old Oct 24, 2022 | 09:39 AM
kraut56's Avatar
looks like a good idea: I would stay away from magnets on a CPS
