2003 S600 Command radio replacement
Old Apr 28, 2025 | 01:05 PM
vadersshuttle's Avatar
2003 Mercedes S600
Looking to replace this since the screen is blurry and CDs get stuck. I have it all ready to come out, but before I unplug it, do I need to know the code just in case, and also need the code for the replacement?
Also, is there a good source for these, or check junkyards?
Old Apr 28, 2025 | 08:18 PM
wallyp's Avatar
2003 S500 2007 GL450
No code needed for the COMAND unit.
Do you have the two removal tools?
Are you aware of the new Android units that will fit and look like stock, but greatly update your electronics at very reasonable prices?
Old Apr 29, 2025 | 08:04 AM
2003 Mercedes S600
Hi Wally, thanks for responding. I am not aware of any tools, the radio is pretty much out, just needs unplugging.
I did some research on aftermarket units and it seemed like a big no, due to the fiber optics and built in amps.
Are there new ones that allow the use of these or are they still bypassed? I checked crutchfield and it seemed the same way.
Old Apr 29, 2025 | 10:44 AM
wallyp's Avatar
No special tools required - I was thinking of the instrument cluster.
You can buy an adapter to change the signal from electrical to optical, but most folks think that they give poor sound quality. To get top sound quality you have to run an optional cable from the new head unit to the left rear fender area.
For many folks, the new Bluetooth capabilities are a major factor, with Google Maps/Waze, music streaming, etc., etc.
Old May 5, 2025 | 02:35 PM
2003 Mercedes S600
So, I think I need to get a new receiver, analog to fiber optic converter and a 6ft cable. I think. It’s pretty complicated if trying to retain the original Bose system
Old May 5, 2025 | 10:25 PM
wallyp's Avatar
If you mean the cable from the new head unit to the rear fender speaker connections, you don't need both the fiber optic adapter and the cable to the rear.
Old May 6, 2025 | 11:02 AM
e350forme's Avatar
fleet
dealer will give you code easily
Old May 6, 2025 | 08:56 PM
2003 Mercedes S600
Thanks Wally. I thought the fiber optic adapter gave better sound, but it’s all confusing to me. Just need to research more, but there isn’t much good info out there on these.
Old May 6, 2025 | 10:22 PM
wallyp's Avatar
Start here, and spend some serious time in research.
https://www.benzworld.org/forums/aud...tics-forum.40/
Old Jun 10, 2025 | 11:57 AM
e350forme's Avatar
fleet
i like to keep things original and recommend just an original comand replacement unit
but they make these little android tables that suction to the wall. amazing fm transmitter, bluetooth, google maps, all android features for 50$ or so. no cables required
Old Jun 10, 2025 | 12:00 PM
e350forme's Avatar
fleet
cant add an image but here is the name of the item. just another temporary option at least
10.26" Wireless Apple Carplay Android Auto Portable BT Car Stereo Touch Screen
