E-ZPass Questions (NY Metro Area)
Old Mar 13, 2006 | 08:47 PM
EMPIRE2007's Avatar
This is already the second E-Zpass I got replace from MTA. It doesn't seems to work with S550's Windshield. Anyone else live in NY area with E-Zpass tag that actual work inside S550?
Old Mar 13, 2006 | 09:29 PM
MBZFAN55's Avatar
BMW M850i Gran Coupe
I was told that the internal EZ-Pass will not function properly due to the coating on the windshield on my 2004 S500. Some have stated there is a non coated area somewhere on the windshield that will allow the "pass" to work, but I could not locate that area. I finally had the black exterior ez-pass mounted in the black mesh of the lower grill. It works fine and no one notices it.
Old Mar 13, 2006 | 10:20 PM
Nevada Jack's Avatar
2011 E350 Cabriolet..White and Almond Mocha
Check the manual...is shows the specific areas you can place the pass. Page 475.
Old Mar 13, 2006 | 10:53 PM
hanniep's Avatar
01 ML55, 91 Supra Turbo, 05 Audi S4
Get the one that mounts on the front license plate bracket, a lot of newer german cars have this problem,...I have mine mounted inside to ther right under the mirror away from the shading, it's works fine,.....
Old Mar 13, 2006 | 10:58 PM
EMPIRE2007's Avatar
I found this secreat area. Going to try again. Thanks
Old Mar 13, 2006 | 11:00 PM
LOL...there is no "secret" area...the manual clearly shows the several locations you can place it.
Old Mar 14, 2006 | 01:00 AM
madolfsson's Avatar
S550, 575M, X5
When you look at the windshield with the right angle and light, you can see a grid pattern in two different areas on the windshield. I but some temporary tape in each corner of this grid when I mounted my radar dector, so I knew for sure it would be in the clear.
Old Mar 14, 2006 | 09:16 AM
04S430's Avatar
2008 Mazda Tribute , 2007 S550.
On Tires, E-Zpass, and so on.
Jack, your information is always useful! You must spend a lot of time studying the S550. Thank you for passing this on.
I am looking forward to read your comments once you have driven, for a while, your new S550.
Best regards,
PeterM.
Old Mar 14, 2006 | 09:29 AM
Best regards,
PeterM.
Thanks Peter. I read the information pretty thoroughly...but I sometimes I have a problem remembering where I saw something. The manual in pdf is nice with the index and subject headings....makes it much easier to find specific references.
I will be posting many images and some narrative (hopefully all positive) after delivery. I plan on picking the car up in Denver and then driving to SC, FL and MS and back to LV. A total of about 6000 miles. If Apple would come out with their new iBook in April, I will buy one and use that to post along the way, otherwise I will be out of contact for about 4 weeks.
Old Mar 14, 2006 | 09:47 AM
04S430's Avatar
Have a safe trip through your beautiful country! I am a bit old to understand modern technology such as iBook; but I can assure you, I will follow the resulting posts.
Best regards, PeterM.
Old Mar 15, 2006 | 03:23 PM
PA55AMG's Avatar
2010 Range Rover S/C 2010 Land Rover LR4 HSE Lux Plus 2007 BMW R1200GS
NJ, I wonder if you ever found info on the locations on your S430. I have an 06 S55, and have only been able to find one spot--down at the bottom of the windshield and offset to the right, right above the end of the left wiper. I don't really care for this location, but it is the only place I have found where my radar detector works properly.
I looked all through my manual and could not find any info.
Thanks.
Old Mar 15, 2006 | 03:26 PM
Thanks.
A little diagram is in the manual for the S430. I saw it but will have to hunt for it. I post when I locate it. I know there is more than one spot.
Old Mar 15, 2006 | 03:42 PM
Location of pass thru for S430
Check the manual on page 269..there are two area available.
Old Mar 15, 2006 | 04:41 PM
jmrdmd's Avatar
2021 C63S Cabriolet, 2021 GLE53 Coupe, 2022 GT3 Touring, 2021 Taycan Turbo S, 2022 F-150 Lightning
License plate mount
Get a license plate mounted transponder. I have it on our SL 500 and the 7. I'll transfer it onto the S550LE when I get it. You dont even notice it and you dont have to have that ugly white box stuck on your windshield! Just my $.02!!
Old Mar 15, 2006 | 05:16 PM
sprink49's Avatar
2004 S500
This is the spot that works for me. This is per my manual and the Sun Pass people here in Florida...but this is THE spot.
Old Mar 15, 2006 | 06:03 PM
You guys ought to move west...no toll roads and no front license plate mounting...LOL
Old Mar 16, 2006 | 08:17 AM
jmrdmd's Avatar
I can almost see NYC...
but it costs more in tolls than fuel to get there! EZpass has been a god send, no more change, tokens, tickets, or greenbacks to exchange!
Jan
Old Mar 16, 2006 | 02:05 PM
PA55AMG's Avatar
Thanks... I must have missed that page in the manual.
My detector doesn't seem to work very well up by the mirror, so I will have to continue to use the lower spot.
Old Mar 16, 2006 | 04:36 PM
mand's Avatar
2006 VW Passat
Whats ez pass?
Old Mar 16, 2006 | 05:00 PM
everyONEelse's Avatar
E500
It's a transponder that allows you to pay toll roads without having to stop to give cash or get change back. Charges are deducted from a credit card you use to sign up.
Old Mar 16, 2006 | 05:09 PM
BklynBenz's Avatar
CL500
the previous s class and cl had the same problem if you wanna call it that
Old Mar 16, 2006 | 05:12 PM
mand's Avatar
2006 VW Passat
Thats cool, in ontario we only have 1 toll road, its a highway it goes a long way, don't know how long though
Old Mar 25, 2007 | 08:35 AM
theteeman's Avatar
2019 C300 Cabriolet
e-zpass clk
does anyone know where the e-zpass can be placed, if it goes behind the mirror does it interfere with the auto windshield wipers?
thanks
Old Mar 25, 2007 | 12:22 PM
02S430's Avatar
W220 M113K
mines is on the front plate works fine
