Keyless Go - is it easily crackable?
basically, they are saying that it's easy to crack remote engine start codes, especially for Keyless Go cars - can't summarize it too well but essentially, the idea is that the key gives a response to the car (or a hacker who's broadcasting as if he were a car) using a rolling 40 bit code, and the algorithm can be cracked if the hacker had two samples to work with.
the reason i'm posting it here is because they specifically mentioned the new S550 as an example. apparently, this has already been shown to work on Ford Escapes and BMW X5s (Beckham's) so i'd like to know how true it is for Merc as well.
http://reviews.cnet.com/4520-3513_7-6516433.html
Until those geniuses at Johns Hopkins can sucessfully crack a Mercedes I will hold my panic.
M
It only works if Halle Berry is your girlfriend and John Travolta is blackmailing you at gun point whilst a hot chick is doing something unspeakable and you crack the code in your laptop. I think life imitates art in the strangest ways.
M
i believe Benz's are easy to open up as they don't have deadlocks: Merc doesn't want them because they're afraid of impeding emergency services in an accident.
but as for driving it away like no one's business, i don't know
256-bit encryption and better exists but as they said, more and more power would be required.
Regardless, 40-bit encryption is easy to crack.
I don't think this system (and Keyless-Go) uses an ordinary encryption like many systems, the system can only be used for a certain amount of times (don't worry: thousands) that would mean that it doesn't follow a certain algorithm but uses accidental generated codes which are safed onto the key and the lock. When a new key gets programmed it takes more time when the car is older (it has to go through all already used codes) it also cannot be manipulated with the tools avaible even at an authorized MB-Dealer (it all becomes controlled from Stuttgart - at least in Germany, maybe there's a different "server" for America?).
I wouldn't worry too much about it, like already said, when they steal your MB, they just take a wracking car and then disassemble it and sell the parts...
OR
Replace several key components and drive off.
at any rate it is true that there are only going to be a few people who have the abilities to pull this off but that is a moot point... the problem is that all it takes is for one guy to break the system and then sell his software to the wrong people. there has been evidence of exactly this happening in the asian markets where luxury vehicle theft is not only more prevalent but much more sophisticated. the biggest problem with this sort of theft is in how it affects the average mercedes owner. right now the perception has been exactly what we have seen here: that you need to be some sort of super spy to steal a mercedes this way. the actual truth is that you only need to be a willing car thief who has access to the proper software. the issue then is that if your vehicle is stolen in this manner your insurance company is going to suspect fraud on your part rather than the possibility that this "ultra-secure" system has been brokenand this is in fact exactly what some unluck people have had to deal with.
