S-600 and "Memory Card Slot"
I just ordered an 07 S600 and it sill soon be here.
there are 2 things that I would like to do to this US car. First is to connect a large Hard Drive via the PCMCIA (Or Memory Card) slot. Currently I have successfully connected an SD card, a MicroDrive, and a Compact Flash card. I have also tried a portable USB drive and a portable Firewire drive via USB and FW PCMCIA cards. Neither of them worked.
Does anyone have any ideas on how to get a say 300 gig drve into this system?
Secondly I would like to add the factory TV Tuner module. anybody know where I can get the parts list for the necessary bits?
Lastly I would like factory schematics of the Command system including all pieces like Phone GPS, etc.
anybody know where to start???
thanks!
thanks!
2004 S55
There could be a variety of obstacles to adding an HDD to the COMAND system via the PCMCIA slot. You could have limitations on how much power you can draw from the slot, what the partition access limit might be on the system, whether the system would properly recognize a PCMCIA firewire or USB host controller, etc. Beyond all that, you may have internal memory limits on how large a directory structure it can "see".
This last item is one of the problems I came across with my current W220 COMAND system when burning MP3 DVDs. The system doesn't officially list support for MP3 DVDs (just MP3 CDs) but it will read them. I've had success with DVDs but run into problems as the track count gets high. At some point, it won't "see" all of them or even all your folders. There appears to be a finite limit in memory about how much directory and filename info it can store (it reads the directory of course before playback to present you with a men list of folders and tracks to choose from). I can't nail down what the limit is, but it certainly exists as discs with fewer tracks read and play fine while larger ones will only show some of the songs on the disc.
There's a hint about this in the online manual for the W221 but it only talks specifically about "File structure on a disc". There's no mention of the same thing for the PCMCIA slot, but that section says:
"When you create an MP3 disc, the MP3 tracks can be organized into folders. A folder can also contain other folders. A disc can contain a maximum of 255 folders. Each folder can contain a amximum of 255 tracks and 255 folders. A disc can contain a maximum of 4,000 tracks."
http://www4.mercedes-benz.com/e/cars...ensystem3.html
That last sentence, if it applies to the PCMCIA slot as well, would seemingly be your hard cap limit for track quantity.
Hope this helps.
Jeff
Hope this helps.
Jeff
Thanks for the info! Hopefully there is a way around this track limit, at least with the PCMCIA slot, as samsung is likely to release 32 and 64 Gig Flash cards in the near future. a 64 gig card would be more than acceptable in terms of capacity.
80gb is roughly 10k songs I'd say.
At least that's whats on my desktop computer right now.
I was under the impression that PCMCIA was in laptops and was obsolete thanks to ExpressSlot?
2004 S55
Jeff
2004 S55
Jeff
thanks!
thanks!
2004 S55
Here's an example app I found:
http://www.ezsoftmagic.com/mp3splitter_joiner.htm
It's one of many MP3 editors out there that will split or combine MP3 files. when you click on the "Split Special" button, there's an option to split the song into an equal number of segments that you specify. The program's maximum is 999. So, you could take 5 different songs and do that to each to give you almost 5000 tracks that collectively should only be as large as the 5 original tracks. It's then a question of sorting the new small MP3 tracks into folders keeping in mind the 255 tracks per folder limitation mentioned in the manual. This particular program is $25 (the demo version caps the number of output splits at 5) but there very well may be others with a similar function that are free.
Jeff
I will give that a shot when the car arrives. It is the obvious first step before going and puchasing a larger CF or SD card. If that is the case, and there is a song limit, maybe coming up with a contact at MOST would be a good place to start the "hack".
Am I correct that mercedes is using MOST for the command system?
2004 S55
Just out of curiosity, have you completely ruled out an iPod solution? The iPod interface kit is now available for the W221 through MB and Apple just bumped up the 5G ipods to 80GB with certainly larger models to come. Sure, the control is only through the steering wheel buttons and the display is only the one in the speedometer area (no song info is displayed on COMAND), but it's a fairly easy path to take.
Jeff
I will be going with the Ipod solution but it is really lame . its very slow, and not very easy to browse a large playlist. Its fine if you have a Nano or something but I have tested using a fully loaded 60 gig player and it is very clunky.
I just don't understand why they would not fully integrate it into the system. It feels like a complete afterthought, which it probably is.
Brian
Brian
2004 S55
Brian
Brian
Instead, they went with a solution that bypasses COMAND in favor of each model's multi-function display and steering wheel buttons. Those are probably much more similar across models than the COMAND units are. So, you wind up with fewer parts needed to accomodate multiple models for the same option.
Certainly, this wouldn't have been my first choice. However, MB has clearly shown that when it comes to technical creature comforts, they are slow to include them and often go with a more basic solution than other manufacturers. Clearlym they don't see this area as a crucial one for driving sales. However, as the digital generation ages and moves into MB's demographic, they better as those folks want more of this kind of thing.
Jeff
Well said...
So far I have gotten to speak with the Head Technical Manager at MOST. They designed the network that all of the modules for the Infotainment system ride on. but those modules were designed by the Harmon-Becker Group. The guy i spoke with is going to get me in touch with the right people at Harmon in Germany. could be prommissing.
But what is interesting is that the MOST guys are able to decifer the data and are willing to provide me with that information if I wanted to say use an external devce yet control it with the Command Controller. So an auto PC running some form of GUI based MP3 player....
Still not choice number 1 but interesting that they are open to this discussion.
