Tires for S550 4matic AMG package
Does it have staggered tire size?
What are the sizes of the tires?
What brands are they using?
Are they highperformance all season or just summer?
What does anyone think of all season ultra high performance for winter?
Do most of you just get winter tires mounted on extra set of wheels?
I think MBUSA sight may not be accurate answers to these questions.
Thanks for the help.
other cars: 2004 CLK 55 cabrairo
2006 ML 500
2000 S500 designo 48,000 mile creampuff that I would like to sell to somone who wants a perfect one owner original list $94,000 absolutely loaded Expresso (Very dark brown)
2006 ML 500
321 AMG Sport Package
The spirit of performance takes form in the S-Class AMG Sport Package. An aggressive AMG-designed front air dam tames the wind, sending it past sculpted, lower side sills and around a seductively styled rear apron.
This package also includes huge, staggered-width 19" AMG 5-spoke light alloy wheels wrapped in 255/40 R19 tires in front, and asphalt-grabbing 275/40 R19 high-performance rubber in back. If you're looking to further accentuate the athletic personality of your S-Class, the AMG Sport Package is the answer. *
* High-Speed Rated tires provide substantially increased tread wear and reduced ride comfort compared to H rated tires. Serious wheel and tire damage may occur if the vehicle is operated on rough or damaged road surfaces or upon encountering road debris or obstacles.
Good luck, and welcome to the forum!
Might want to check in the Tire forum to be sure. Luke could probably help you.
http://www.mercedes-benz.de/content/...lasse_W221.pdf
Unfortunately staggered tires are not available for 4MATIC S-Class. It is surprising that they put them on the ML but not on the S.
Search some before you speak.Look at page 17 of 32.
http://www.mercedes-benz.de/content/...sse_060801.pdf
Mischbereifung= Staggered tires.
HA= Hintere Achse= Rear Axle.
VA= Vordere Achse= Front Axle.
Basically a file that you see with Adobe Acrobat.
"...without the proper diameter tires the 4-matic system can easily be damaged which would be a very expensive mistake and not something I would recommend. There are some cars (i.e. E55 4m, Porsche C4, etc.) the are all wheel drive with staggered wheels and tires but, their electronics and all wheel drive systems were designed with that in mind unlike yours ... I would go with 18x8 / 245/40-18 or 235/40-18__________________
