Radar Detectors and Distronic Plus
Can someone enligthen us on whether this is a problem?
SOME S classes have distronic plus (not regular distronic.. only distronic plus) and will have radar interference on K band... Your detector will go off all the time with K alerts.
ALL S classes have the coated glass which severely limits the amount of radio waves that get into the vehicle. Since radar detectors need the radar waves to actually get into the detector to work this is going to be a problem unless you go with a bumper mounted unit.
I'm so mad...
I have an ML 2007 with Distronic (simple, NOT plus).
I have problem with the radar detector: Beltronics rx75 plus
The first one got stuck and did not detect anything. After a big speeding ticket and filmed prouves, the dealer changed the detector with a brand new one (it costs ± 1000 USD).
This one is working very well, so good that I cannot use it because it's always in alarm !!!
Can it be an electrical problem ?
I'm going crazy here...
The S550 owners manual describes these 2 areas, one which is used by the night vision camera if the vehicle has that option.
and regardless about the film, if you have D+ your still not getting a radar detector to work without some extra cash. I did a few for the local dealership, with my own interface, rob came out with his own interface also which he markets to the world, and the dealership just does it if you go to them.
(I got a brand new one for $199 plus my old detector) As far as the location of my detectors, they ARE right in the lower center of the windshield on all my cars that have V1s. To be honest, I never knew about the 'infrared coating' on Mercedes windshields! I've gone all around town and some short freeway trips
, and my V1s have always given me plenty of warning time from Laser and K band radar signals. I just don't know what to tell you about your particular V1 problem. Sorry, MichaelNever new about the infra red metal placed on the windshields and just had mine hardwired in?
By the way, I have also tried the escort 9500i that ties up with GPS and is not supposed to go off under 30 miles/hr - well - sorry to say - that one goes crazy as well (as soon as you start the car) - This is plain utter stupidity and nothing else (IMHO) - This car is not for use in the USA - Auto Bahn -way to go ..
And, you must mount the detector in the small rectangle space to the left of the rearview mirror (without the infrared coating) or it won't work at all.
But, it's possible!
Contact your "Toll Tag" authority (the rectangle space to the left of the rearview mirror is designed for a toll tag sticker). The Toll Tag authority here in Texas also has a special request front license plate sticker to use in case your car has the infrared windshield coating. Get this license plate sticker as the windshield rectangle is being used by your Valentine One!
you could just as easily unplug the radar detector 42 minutes out of each hour and get the same results...
The 9500ic has 2 functions, the radar signal detectors and the laser diffusers. Both functions will be performed by means of two components mounted behind/under the rear and front bumpers.
The Mid-City interface will make the 9500ic reading's show in the instrument cluster (not the Command screen), and most of the controls handled by means of the streeing wheel controls.
I don't have Distronic, so I am not worried about the Distronic produced K signals producing "false" alarms.
Given the planned location for the installation of my equipment, I am not sure that the Distronic signals would be picked up by the radar signal detectors. Maybe someone with more knowledge will chime in. If I am correct, then the equipment I am using will be the answer even for those owners with Distronic.
Even if you plug in a dash mount detector it is going to make it go crazy reading K band.
If you have any other questions let me know and ill see if i can answer them for you.
I saw this and thought I would include my 2 cents..... That PDF is old, I contacted K40 on this and at one time that may have been true. But it is no longer true K40 DOES OFFER several solutions to MB with Distronic Plus.
The 9500ic has 2 functions, the radar signal detectors and the laser diffusers. Both functions will be performed by means of two components mounted behind/under the rear and front bumpers. The 9500ci comes with ONLY 1 radar reciever and 3 laser shifters. They also recommend there radar recievers to be mounted on the outside which all of my testing should that there recievers are vulnarable to getting water damge, if you dont believe me take one of there recievers and hold it under water for 3 minutes I assure you, you will see bubbles. The K40 provides more protection by incorporating a rear radar reciever. And they keep the original look inside you vehicle.
http://midcityengineering.com/radar-...rfaces/k40d221
