Can Blind Spot Assist be retrofitted?
My irritation is because Park Assist was/is clearly listed as an inclusive feature in the dealers print out of my vehicles VIN# and associated feature specification - the confirmation of which was the basis of my order... Whether one uses Park Assist or not, it is part of the marketed value proposition of the S-Class... The situation is even more egregious in the case of those MY07 owners who originally had this functionality and have now had it removed when MB updated their COMMAND system.
It is not as if the technology has been de-contented either.. as NJS430 points out it has been reintroduced in the post July 2008 models... and cheaper and with the additional Blind Spot Assist!
There is a point of principle here...
So MB can take refuge behind "MB reserves the right to make changes at any time, without notice to colors, materials, equipments, equipment, specifications, and models", but I am sincerely hoping that MB cherishes it customers in this price range, and will introduce an upgrade option for existing S-Class owner with this functionality... Even my SA is amazed about the current situation... I am waiting, but hoping that the recent COMMAND upgrade for the MY07 cars is a positive precedent/gesture..
Having said that, from what I see/hear I would certainly find Blind Spot Assist a highly useful feature and would definitely like to retroactively fit that if possible...
Chris
Many of these socialists/populists/communists/whatever don't "get" how real economies function...or how tax revenues are generated....
Thankfully, many of the major tech and financial guys in SiliconValley and SF are car nuts
Def a very polarized place.....even SiliconValley has quite a contingent of confused Prius-driving/G550-flying "environmentalists"....
Happy New Year
Sounds different but perhaps something similar to here:
https://mbworld.org/forums/showpost....03&postcount=9
If anyone has a MY08 and can really access this feature - then I would love to hear it.
Chris
All post-July 08 build cars have the newer package. Don't know why MBUSA is quiet on the subject - even the 08 manual has no mention of the new features. I bet there are a hundred people out there who don't have a clue why they have a P in the middle of their speedometer that turns blue every so often. Took me two weeks to figure out I had it and I am not your average Mercedes owner - I need to know how everthing works.
Don't know if there is a way to retrofit it to the older cars - but MBUSA should do it for those who want it. I would try writing to Ernst Lieb - seems like a guy who really wants to be #1 - not something he is going to get if people buying the most expensive Mercedes feel cheated.
Parking Guidance*
Parking Guidance is an electronic parking aid with radar sensors. The radar sensors are used to measure the road on both sides of the vehicle. It indicates suitable parking spaces and provides steering instructions to help you park in the indicated spaces.
Parking Guidance is only an aid, and the indicated parking spaces may not be suitable for parking due to parking prohibitions, or because they are driveways, or because of unsuitable surfaces and so on.
The Parking Guidance display in the instrument cluster is only a symbolic display of the parking space as measured when first driving past it. Later changes to the parking space are not taken into account, e.g. if the vehicle parked in front of or behind the space has changed its position, or if obstacles are moved into the parking space. Moving objects, such as pedestrians and passing vehicles, are not displayed.
Parking Guidance does not relieve you of the responsibility to pay attention. If you rely solely on Parking Guidance, you could cause an accident and injure yourself and others.
You are always responsible for safety and must continue to pay attention to your immediate surroundings when parking and manoeuvring.
Make sure that no persons or animals are in the manoeuvring range. Otherwise, they could be injured.
You must deactivate the radar sensor system in certain countries and near radio telescope facilities. Further information can be found in the index under "Radar sensor system".
Vehicles with COMAND and navigation*: the radar sensor system is automatically deactivated near radio telescope facilities.
If you want Parking Guidance to assist you, the radar sensor system must be activated and operational.
- that are parallel to the direction of travel
- that are on straight roads, not bends
- that are on the same level as the road, i.e. not on the pavement, for example. Parking Guidance may not detect flat kerbs.
- On narrow roads, drive as close to the parking space as possible.
- Parking spaces which are littered, overgrown or in front of trailers might not be identified properly.
- Pay attention to the Park Assist warning messages when using Parking Guidance.
- The position of your vehicle in the parking space after using Parking Guidance depends on the position and shape of the vehicles parked in front and behind, and on the conditions of the space. In some cases, Parking Guidance may guide you too far into a parking space, or not far enough into it. In this case, you should cancel Parking Guidance and correct the vehicle's position.
Parking Guidance is automatically activated when you are driving forwards. When driving at speeds below 16 km/h, you will see the white parking space symbol as the system display in the instrument cluster. The parking space symbol turns blue as soon as Parking Guidance has detected a parking space.
Detected parking space1 Detected parking space on the left 2 Parking space symbol 3 Detected parking space on the right
- that are bordered at the back
- that are at least 1.5 m wide
- that are at least 1.0 m longer than your vehicle
Parking
The following instructions refer to parking in a space on the front-passenger side. To park in a space on the driver's side, mirror the instructions.
Parking Guidance will emit a warning tone if it detects an obstacle behind the vehicle while you are parking. Stop immediately. The parking space and the lane begin to flash in the instrument cluster. Make sure that there is no danger before continuing to drive. The display in the instrument cluster stops flashing when Parking Guidance no longer detects an obstacle. You can continue parking.
Parking Guidance is only an aid and may not detect all obstacles. Parking Guidance may not be able to detect objects in corners or on smooth surfaces. Parking Guidance does not relieve you of the responsibility to pay attention.
You are always responsible for safety and must continue to pay attention to your immediate surroundings when parking and manoeuvring. You could otherwise endanger yourself and others.
Stop the vehicle when the blue parking space symbol shows the desired parking space in the instrument cluster.
Engage reverse gear.The multi-function display shows the message: Check surroundings Confirm with OK.
Press
on the multi-function steering wheel to confirm.The display in the instrument cluster switches to Parking Guidance.
1 Green lane 2 The white bracket marks the target position.
Depending on the distance, you may have to reverse along the lane towards the parking space. This is also represented by a green lane 1 .Continue reversing until you hear a warning. Stop the vehicle, you have reached the target position indicated by a white bracket 2.
Steering tips1 The red lane indicates the lane you are on with the steering wheel in its current position.2 The yellow lane indicates the lane you will reach when you have turned the steering wheel in the required direction.
Turn the steering wheel while the vehicle is stationary until red lane 1 and yellow lane 2 overlap.Lane 2 turns green. If the parking space is inside the area displayed, the end of the green lane is marked with a white bracket and an arrow showing the position you are aiming for.
Driving into a parking space
1 The lane turns green when the steering wheel is turned in the right direction.
Keep the steering wheel in that position and reverse carefully.
Stop as soon as you hear a warning.The vehicle has reached the position in which you need to countersteer.
Countersteering
1 The red lane indicates the lane you are on with the steering wheel in its current position. 2 The yellow lane indicates the lane you will reach when you have turned the steering wheel in the required direction.
Turn the steering wheel while the vehicle is stationary until red lane 1 and yellow lane 2 overlap.Lane 2 turns green, and a white arrow and white bracket indicating the target position appear.
Driving to the final position
Keep the steering wheel turned in that direction and reverse carefully until you have reached the final position.The multi-function display shows the message: Parking Guidance finished and a warning sounds.
If the rear gap is too small, Park Assist emits an additional warning tone .
Final positionDepending on the size of the parking space, you may now be in an angled position in the parking space. If possible, Parking Guidance will guide you as far back as possible towards the rear limit of the parking space.
Manoeuvre if necessary.
Pay attention to the Park Assist display.Cancelling Parking Guidance
Press the Park Assist button in the dashboard.Parking Guidance is cancelled immediately and Park Assist is deactivated. No message appears in the multi-function display.
Parking Guidance is cancelled automatically if it is no longer possible to guide you into the parking space, or if a malfunction occurs.
The parking space symbol goes out and the message Parking Guidance cancelled appears in the multi-function display.
Trailer towing*
Parking Guidance is automatically deactivated if it detects that you are using a trailer tow hitch or have fitted an item such as a bicycle rack on the rear. The parking space symbol does not appear
In any case a very useful post on the park guidance feature.
You are correct that MB is extraordinarily quiet about this. As I bought my S600 in September when the 07/07 models were already in manufacture and being distributed, had MB given me the data on which to make my decision that would have impacted the final vehicle I would have purchased/accepted. To that extent I do feel cheated, though I am certainly happy with the S600 as an overall vehicle.
I accept that maufacturers will continue to change specifications etc - that is a risk of any purchase, but "Parking Guidance" (specifically) is obviously a replacement for the "Park Assist" type functionality that has always been sold/marketed as part of the S-Class (certainly S600) value proposition - and to leave customers without this feature at all without explanation - is in effect a de-valuation of our cars functionality by MB without compensation or notice. The price is the same for either a 06/7 to a 07/07 S600 and the current situation for any S550/S600 owner who has already paid money for this area of functionality as advertised is not equitable.
I recall in the situation of MY07 models sold without the Traffic Update, Birds Eye View etc, there was a slight reduction on the sticker price to compensate - and even then MB introduced the COMMAND update for these owners. I am sincerely hoping they will do a similar upgrade in this situation.
I would email/write to Ernst Lieb (mbusa CEO) if anyone knows where to email/write to?
Chris
I believe those are separate option codes from the factory too, just put a SCN accordingly and the parking guidance should be there???
One suspicion is that early MY08 cars may have the older MY07 COMMAND system installed, (the "real" MY08 only being introduced from 07/07) but that they had the COMMAND upgrade applied at the port removing the Park Assist feature?
The core principle remains that Parking Assist/Guidance functionality is explicitly marketed as standard on the S600 for its price and I have not received what others who aquired vehicles shipped a month later did. The Blind Spot Assistance is kind of a separate issue in my mind as that had no precedent in earlier vehicles. (Much as I would like it) Parking assist type functionality (whether Parking Assist or Parking Guidance) has always been sold as part of the w221 S-Class right from its launch and continues to be promoted as a part of the vehicle. (Except if you are an early MY08 owner!)
Anyway all I seek is a clarification of the situation from MB if I can figure out how to talk to them. I have never had cause for a complaint like his before. This is not really a dealer issue and more to do with mbusa corporate - are there any suggested routes to take this?
Chris
What I find interesting is that you could/should have had what is apparently a more sophisticated parking technology which MB feels is now superior to the 'old' Park Assist and which they introduced as of July '08 production for the US. This new feature is called 'Park Guidance' and it is radar based. And your MY08 S600 would have had this feature...if only your car would have gone through the production line in Sindelfingen just 4 weeks later or less! In my humble opinion, this is a better case to make to MBUSA. "If the dealer would have told me that 'Park Guidance' would be available shortly...or MB would have posted on the window sticker of the S600 I was about to buy that MB was giving me certain $ credit because my particular early MY08 did not have this feature (e.g. case of early S63/CL63 with new Nav features), I would have passed on it and happily waited four weeks to purchase another later production MY08 S600 with these advanced features". Ditto argument for the new 'Distronics Plus' with Blind Spot Assist. That line of reasoning might get you better results at Montvale. Just a thought. Regards, Z356.
Chris
It's a great car with or without the extra features but you make a good point about Park Guidance being only software. Since the sensors are probably the same and the screen wouldn't need updating, this should be an easy install and there is no reason Mercedes shouldn't offer it to you. BSA would require new mirrors and maybe wiring that just isn't there.
Is there anyone out there who has access to the technical data who can verify just what would be needed?
Now I'm not suffering the loss of features and I want to leave this topic now, just hope everyone can enjoy the car with the features they prefer.
Parking Guidance*
Parking
Press
Countersteering
Trailer towing*
Chris
Just a minor update on this issue. I spoke with my SA today and he was also talking to the factory representative who was well aware of this problem. Seems there may be a new COMMAND update of some sort in the works - at least I got a strong sense that I am not the only one complaining about the loss of Park Assist and that MB is aware they have an issue to deal with here. Will keep the board updated.
Chris
Chris
I brought this to the attention of the MBUSA AMG product manager as well. I hope they can see their way clear to helping us out.
J
Good luck in getting the update.
First, Blind Spot Assist (234) only appears once in EPC in relation to the bumper radar sensors. This is for the rear in the option combination "229/230/234". Secondly, there are basically two different sensor types only (taking into account current versions only), the same sensor parts are used both in the rear and in the front. My car is using a different sensor from the one above (this car has options 233 and 229). EPC does not have any entry for a case where the car would have all 233, 234 and 229/230 while cars like this must exist. EPC does mention a date range for the two, but not for all car variants. I'm sure you are lost with this analysis, you should see the list really (I don't dare to post it here).
I assume the two different sensor parts are actually interchangeable and as long as it is clear that both are used on a car with 230 + 233, all Distronic Plus cars must have BSA compatible bumper radar sensors. I would be happy to see a second opinion from someone who has had a look at this section of EPC.
The question was about BSA but it looks the same for the Advanced Parking Guide (this is what EPC talks about, the marketing names were mentioned in an earlier post in this thread).
I'd conclude the new features being SW only, except for the rear view indicator glass (and wiring possibly).
Finally if you don't remember the option codes:
233 Distronic Plus
234 Blind Spot Assist
229 Park Assist
230 Advanced Parking Guide
I agree. From my perspective, I find the blinking mirrors a little distracting anyway. I'd go for just the warning beep if one tries to change lanes. I asked MBUSA to consider a SW update to allow for advanced park guidance and BSA without the mirror lights.
J
