How to enable Dyno Mode (Instructions In Post)
Dyno mode is mainly intended for testing the car on a dynamometer, where only rear wheels move. All ABS/ESP etc. features are completely switched off in order not to interfere with dyno or similar testing.
Definitely not intended for normal driving.
At first gear, the CDI should actually have more torque (and power) where the rear wheels start to burn rubber. I haven't tried it, and will not, but I assume the torque converter would not allow engine RPM go high enough where the S550 would make more HP compared to the CDI (even 320). Here I mean the case of burning rubber, car practically stationary and rear wheel "speed" pretty low.
On a normal acceleration, the CDI should do the same for the very start but once engine RPM would go above 2000 or so, the S550 would start accelerating faster. I actually looked at the engine power/torque figures, at 2000 RPM the 320CDI has more power than the S550 at 2000 RPM, at 3000 RPM S550 is marginally better, the CDI would stop doing better at 4000 RPM while the S550 really gains a lot more power beyond 4000. This is why the S500/S550 makes a lot better for 0-100km/h.
The CDI would beat the S550 at the point the tyre first loses it's grip and from that onwards should be "easier", I would not be surprised if these two cars burn rubber the same way. Anybody willing to try
http://www.brabus.de/en/raster.php?p...59&kategorie=9
or theres this mob who say 51 hp and 85nm
http://www.dieseltuner.co.uk/mercedes.html
Keep telling myself it's not in keeping with the type of car..
